Hello,
So, I've recently upgraded my PC to a Gigabye GA-P55-USB3 Mobo. I also got a i5 750. I heard that the 750 was a great OC CPU, and for the $40 I bought it for, I was sold. I've done some playing around, and I think I've found the sweet spot of a 3.4 ghz OC. This OC is on a stock Intel 1156 socket heatsink/fan. I idle at around 53-55 C. I've tried 3.5 ghz, and I ran at idle of 60-65c. That is a huge jump. I hit around 80-83c under load in Prime95, and around 77-80c on The Divison. Pretty solid temps for a stock cooler. My concern is, why is there such a big jump from 3.4 to 3.5 ghz? I was at about 96-99c at 3.5 ghz in The Division, and I was too afraid to try Prime95.
It would be great to get some OC advice!
Thanks,
Ricky
https://linustechtips.com/topic/577009-i5-750-overclock-temps/
temps are related to the voltage your cpu is running at. If you need so much more voltage to reach stable 3.5 GHz than for 3.4 GHz, it is obvious that the temps are rising quickly.
But pls do your cpu a big favour and give her a good aftermarket cooler
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
https://linustechtips.com/topic/577009-i5-750-overclock-temps/#findComment-7547410
Try changing your voltage.
Auto voltage uses too much sometimes and that causes more heat.
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
https://linustechtips.com/topic/577009-i5-750-overclock-temps/#findComment-7547411
15 minutes ago, S1ickRick said:
Hello,
Thanks,
Ricky
do not overclock with voltage set to auto, motherboards are too stupid to try low voltages and just ramps up the voltage to what it thinks is necessary and usually that is too damn high.
CPU: R5 1600 @ 4.2 GHz; GPU: Asus STRIX & Gigabyte g1 GTX 1070 SLI; RAM: 16 GB Corsair vengeance 3200 MHz ; Mobo: Asrock Taichi x470; SSD: 512 gb Samsung 950 Pro Storage: 5x Seagate 2TB drives; 1x 2TB WD PurplePSU: 700 Watt Huntkey; Peripherals: Acer S277HK 4K Monitor; Logitech G502 gaming mouse; Corsair K95 Mechanical keyboard; 5.1 Logitech x530 sound system
 01000010 01101001 01101110 01100001 01110010 01111001 00100000 01100100 01101111 01100101 01110011 01101110 00100111 01110100 00100000 01101101 01100001 01101011 01100101 00100000 01111001 01101111 01110101 00100000 01110000 01110010 01101111 00101110
https://linustechtips.com/topic/577009-i5-750-overclock-temps/#findComment-7547422
I do have the board set to auto voltages. I actually watched a NCIX video with Linus who overclocked an i7 8XX CPU, and he enabled the auto Vdroop. I tried that, and about 5C more in degrees. Turned the auto Vdroop off, and used just auto voltage, about 5c cooler. I will try playing with the voltages manually tomorrow after work!
Thanks for the comment!!
https://linustechtips.com/topic/577009-i5-750-overclock-temps/#findComment-7547440
