2 minutes ago, FireFox_13 said:
I own a Nexus 7 2013 model which apparently isn't working. It displays some kind of bars. This happened to me a few months ago, but yet its happening again. Please help me out here ,any suggestions on how to fix it ?
Picture please?
Please spend as much time writing your question, as you want me to spend responding to it.  Take some time, and explain your issue, please!
If you need to learn how to install Windows, check here:  http://linustechtips.com/main/topic/324871-guide-how-to-install-windows-the-right-way/
Event Viewer 101: https://youtu.be/GiF9N3fJbnE
Just now, FireFox_13 said:
i did attach a picture with it
Thank you, to me that looks like the display itself is bad...  You should look into a replacement.  You could also check and ensure that it is actually plugged in well.
Okay , THANK YOU !!!! I'll definitely do that
is it just a display problem or Firmware issue ? Because the last time it happened , I did a reset and everything was fine again ! Until it happened again
