Network Advice
Go to solution Solved by RedWulf,
4 minutes ago, sauer119 said:
Ok what is the best router to have that is some what cheap and easy to manage.
I'd say just hit local stores or amazon, find the features an price that you like. As long as it has an "AP" or "access point" mode you should be good. I would recommend it had dual or 5ghz bands. If you want easy network storage, some of the nicer routers have usb ports. Netgear and asus are pretty good, just check user reviews.
If you want to do in-wall work you can wire a keystone or two. Other than that you could use a router in AP mode or a switch with an additional AP. The router is the easiest and most manageable option.
                   _/ V\
    ______|   __/_/| |
   /_______\______}\__}
[I5-12600k | 32gb DDR5 6000 | RTX5070 | 2x1tb M.2]
[Ryzen 5 1600 | 16gb DDR4 3200 | GTX1030 | 4x 8tb HDD]
https://linustechtips.com/topic/576810-network-advice/#findComment-7545489
Will the routers conflict with each other?
https://linustechtips.com/topic/576810-network-advice/#findComment-7545521
PCIE Wifi is the best wifi if you don't already have one, but Ethernet is still gonna be faster almost all the time.
MSI GE72 Apache Pro-242 - (5700HQ : 970M : 16gb RAM : 17.3" : Win10 : 1TB HDD : Razer Anansi : Some mouse) - hooked up to a 34UM58-P (WFHD) in dual screen
iPad Air 2 (for school)
iPhone 6
Xbox One Forza 6 Limited Edition Blue
https://linustechtips.com/topic/576810-network-advice/#findComment-7545532
For your use, no just use AP mode
on a technical level, there is technical interference though wi-fi overlaps all the time without issue. If you can I would say use 5ghz band since its just in your room and 2.4ghz on the other.
                   _/ V\
    ______|   __/_/| |
https://linustechtips.com/topic/576810-network-advice/#findComment-7545534
I already have a router it just isnt close to my room i have an Ethernet cable ran to my room i just want to boost my WiFi and still have Ethernet capabilities
https://linustechtips.com/topic/576810-network-advice/#findComment-7545539
https://linustechtips.com/topic/576810-network-advice/#findComment-7545562
                   _/ V\
    ______|   __/_/| |
https://linustechtips.com/topic/576810-network-advice/#findComment-7545588
Thank you
https://linustechtips.com/topic/576810-network-advice/#findComment-7545592
Set them to operate on different 'channels' for both the 2.4GHz and 5GHz bands to minimise any interference between them.
A router is the best option here as it provides an additional wireless access point for your LAN, as well as extra ethernet ports.
When it comes to routers, you pay more for faster wireless transfer speeds, e.g. an AC1750 router will be more expensive than an N300 router.
in terms of management interfaces, each manufacturer generally has a consistent interface between all their products. I can personally recommend Asus. Check the likes of Amazon for routers in your price range.
 Almost as cool as my temps
https://linustechtips.com/topic/576810-network-advice/#findComment-7545601
