Hey everyone,
I whipped up a quick PC on part picker for a friend, he has £600 for a budget and I came close with this build. Obviously it has gone over, so I was hoping you guys could alter it so that it manages to make it under budget or very close to.
Here is the link for the build
EDIT: I have done some tinkering, updated the link to the build. I just changed the processor from an i5 6600k to the i3 6100 after doing some research on the chip.
https://linustechtips.com/topic/576169-build-help-needed/
Switch the psu, my system sometimes doesnt boot which leads me very frustrated because of the series of CX psus. Get the RM,RMi, or RMx series if you want corsair's brand. Also, get a decent mid tower like the corsair-spec 01, its a very clean case without being overpriced.
https://linustechtips.com/topic/576169-build-help-needed/#findComment-7539566
1 hour ago, TangoSheep said:
Should get a less expensive motherboard and just get an i5
PCPartPicker part list: http://uk.pcpartpicker.com/p/sz74XL
Price breakdown by merchant: http://uk.pcpartpicker.com/p/sz74XL/by_merchant/
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  (£165.00 @ Amazon UK)
Motherboard: Gigabyte GA-H110M-S2HP Micro ATX LGA1151 Motherboard  (£58.90 @ Dabs)
Memory: Crucial 8GB (1 x 8GB) DDR4-2133 Memory  (£27.48 @ Ebuyer)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (£39.86 @ Amazon UK)
Video Card: Sapphire Radeon R9 380 4GB NITRO Dual-X OC Video Card  (£169.98 @ Ebuyer)
Case: Fractal Design Core 1000 USB 3.0 MicroATX Mid Tower Case  (£36.99 @ Ebuyer)
Power Supply: Super Flower Golden Green HX 550W 80+ Gold Certified ATX Power Supply  (£63.48 @ Aria PC)
Total: £561.69
Generated by PCPartPicker 2016-04-03 21:57 BST+0100
https://linustechtips.com/topic/576169-build-help-needed/#findComment-7539598
SSD!
Desktop Build Log http://linustechtips.com/main/topic/486571-custom-wooden-case-with-lighting/#entry6529892
thinkpad l450, i5-5200u, 8gb ram, 1080p ips, 250gb samsung ssd, fingerprint reader, 72wh battery <3, mx master, motorola lapdock as secound screen
Please quote if you want me to respond and marking as solved is always appreciated.
https://linustechtips.com/topic/576169-build-help-needed/#findComment-7539702
