I've got a new system and messed it up a little bit with installing things on work hard drives and older drivers and tried moving things. I want to completely restart everything. Including the OS. However, I've already installed Adobe CC and photoshop, premier etc. If I do a clean restart of my system will I be able to re install them? Can I just go on the website and sign in and reinstall it?
(Side note) do drivers have to be installed on the same hard drive as the OS? Or can I keep my ssd for solely just my OS? If I can how do I stop things downloading into it?
https://linustechtips.com/topic/576144-system-wipe-queries/
It doesn't matter what is installed where, and personally I just keep a separate downloads folder on my E: drive which I have redirected chrome to download to, but there is a way to change the downloads folder and similar folders' locations.
Also yes, I don't see why you would not be able to reinstall those programs (especially as they are made for professionals who may work on more than one system).
||| Drakon (Desktop Build) |||
|| CPU: 3800X || Cooler: Kraken X63 || Motherboard: B450 Aorus M || Memory: HyperX DDR4-3200MHz 16G ||
|| Storage: 512GB 970 Pro + 500GB 850 EVO + 250GB 850 EVO + 1TB HDD + 2TB HDD || Graphics Card: RX 5700 XT Red Devil || Case: Thermaltake Core V21 || PSU: XFX XTR 750W 80+Gold ||
https://linustechtips.com/topic/576144-system-wipe-queries/#findComment-7538779
1) Yes, you can install CC after reinstallation.
2) Drivers can be put in whatever folder you want, whether it's, par exemple, C:/Intel or D:/(insert random number of random folders)/Intel. You can keep your SSD solely for OS, but drivers will load slover of a mech drive, so keep that in mind.
3) What stuff do you want to stop installing?
Athlon X2 for only 27.31$   Best part lists at different price points   Windows 1.01 running natively on an Eee PC
My rig:
Celeronator (new main rig)
CPU: Intel Celeron (duh) N2840 2.16GHz Dual Core
RAM: 4GB DDR3 1333MHz
HDD: Seagate 500GB
GPU: Intel HD Graphics 3000 Series
Frankenhertz (ex main rig)
CPU: Intel Atom N2600 1.6GHz Dual Core
RAM: 1GB DDR3-800
HDD: HGST 320GB
GPU: Intel Graphics Media Accelerator (GMA) 3600
https://linustechtips.com/topic/576144-system-wipe-queries/#findComment-7538799
Just random downloads and programmes and stuff. Just don't want to clog up my OS ssd. I have an SSD for os and a 3tb mechanical hdd for storage. Should I get another drive specifically for video editing software? And photoshop etc.?
https://linustechtips.com/topic/576144-system-wipe-queries/#findComment-7538834
