P2 is superior
https://linustechtips.com/topic/576016-power-supply-advice/#findComment-7537318
Both are equally excellent units, and have really long warranties.
Really, it just comes down to the feature list. Which one's features attract you? Does it justify the price?
DAYTONA
PROCESSOR - AMD RYZEN 7 3700X
MOTHERBOARD - ASUS PRIME X370-PRO
RAM - 32GB (4x8GB) CORSAIR VENGEANCE LPX DDR4-2400
CPU COOLING - NOCTUA NH-D14
GRAPHICS CARD - EVGA NVIDIA GEFORCE GTX 980Ti SC+ ACX 2.0 w/ BACKPLATE
BOOT and PROGRAMS - CORSAIR MP600 1TB
GAMES and FILES - TOSHIBA 2TB
INTERNAL BACKUP - WESTERN DIGITAL GREEN 4TB
POWER SUPPLY - CORSAIR RM850i
CASE - CORSAIR OBSIDIAN 750D
https://linustechtips.com/topic/576016-power-supply-advice/#findComment-7537421
Assuming that you indeed need a 850w, how much they cost in your area? You could get the RMi instead. It's based on the same CWT platform with the same Corsair Link features and warranty, at a reduce efficiency, but offer superior voltage regulation and ripple suppression thanks to the added v.sense wires and capacitors on the new Type 4 cables.
https://linustechtips.com/topic/576016-power-supply-advice/#findComment-7537424
25 minutes ago, jordanataylor0 said:
There is literally a $15/£20 difference between gold and platinum chances are i probably will go for the hx850i but I've heard a lot of good things about evga too.
I believe £20 is $28 USD, atm. Quite honestly, that's not worth spending the extra money on, especially since Corsair had made some improvements on the platform when the RMi was release a half year later.
It's up to you either way. They both are excellent units nonetheless, as with the P2 series.
https://linustechtips.com/topic/576016-power-supply-advice/#findComment-7537562
2 hours ago, jordanataylor0 said:
Hello,
I was wondering which power supply i should be getting for my high end system. Which would be better out of a Corsair HX850i and a EVGA Supernover 850 p2? or if you have a better suggestion in that price range please reply, thankyou.
The cheaper of the two is fine.
https://linustechtips.com/topic/576016-power-supply-advice/#findComment-7537848
