4 minutes ago, squishyy said:
What i5 cpu should I pair with an r9 390, 6500 or 6600? is the performance increase from the 6600 worth it?
Are you wanting to go sky lake? Or do you want to save money?
Laptop: 2024 16" MacBook Pro M4 Pro, 512GB, 48GB Unified Memory | Phone: iPhone 16 Pro Max 512GB | Wearables: Apple Watch SE | Car: 2025 Honda Accord SE & 2007 Ford Taurus SE | CPU: R7 5700X | Mobo: ASRock B450M Pro4 | RAM: 32GB 3200 | GPU: Sapphire Nitro+ 9070XT | Case: Fractal North | OS: Win 11 | Storage: 1TB Crucial P3 NVME SSD, 1TB PNY CS900, & 4TB WD Blue HDD | PSU: Seasonic Focus GX-850 | Display: LG 27GL83A-B 1440p @ 144Hz, Dell S2719DGF 1440p @144Hz | Cooling: Noctua NH-U12S | Keyboard: G610 Orion Cherry MX Brown | Mouse: G305 | Audio: Audio Technica ATH-M50X & Blue Snowball | Server: 2024 M4 Mac mini, 256GB SSD, 16GB Unified Memory | Storage: Terramaster D4-320 DAS (12TB Seagate Ironwolf Pro, 12TB Seagate Ironwolf, 6TB WD Blue HDD, 500GB Crucial SSD)
https://linustechtips.com/topic/575893-help-pleeeaaaase/#findComment-7536280
No. Pair it with the i5 6500.
Quote
The problem is that this is an nVidia product and scoring any nVidia product a "zero" is also highly predictive of the number of nVidia products the reviewer will receive for review in the future.
On 2015-01-28 at 5:24 PM, Victorious Secret said:
Only yours, you don't shitpost on the same level that we can, mainly because this thread is finally dead and should be locked.
On 2016-06-07 at 11:25 PM, patrickjp93 said:
I wasn't wrong. It's extremely rare that I am. I provided sources as well. Different devs can disagree. Further, we now have confirmed discrepancy from Twitter about he use of the pre-release 1080 driver in AMD's demo despite the release 1080 driver having been out a week prior.
On 2016-09-10 at 4:32 PM, Hikaru12 said:
You apparently haven't seen his responses to questions on YouTube. He is very condescending and aggressive in his comments with which there is little justification. He acts totally different in his videos. I don't necessarily care for this content style and there is nothing really unique about him or his channel. His endless dick jokes and toilet humor are annoying as well.
https://linustechtips.com/topic/575893-help-pleeeaaaase/#findComment-7536300
2 minutes ago, squishyy said:
I'm wanting to go with skylake. I'm good to spend some money around the price range for both of those cpus.
Mind as well go all out. https://pcpartpicker.com/part/intel-cpu-bx80662i56600k
i5- 6600k and the R9 390
https://linustechtips.com/topic/575893-help-pleeeaaaase/#findComment-7536301
1 minute ago, squishyy said:
nope, that's why the non-k 6600 is in my options
In that case, go 6500 if you cant OC
https://linustechtips.com/topic/575893-help-pleeeaaaase/#findComment-7536303
okay. the increase performance in the 6600 is not that noticeable in gaming?
if anything it will be like 2 fps difference
https://linustechtips.com/topic/575893-help-pleeeaaaase/#findComment-7536312
1 minute ago, Toxicknight79 said:
then I would honestly  go with the 6600K still because its a higher stock clock.  i was going to say 6500 but thinking about it  if you have the money to spring for the 6600K ,,, the higher clock will benefit you.
alright, it's just that z-boards for the skylake are pricey. i'm going with a b150 board
https://linustechtips.com/topic/575893-help-pleeeaaaase/#findComment-7536324
Just now, squishyy said:
why? :D
http://ark.intel.com/compare/88184,88188
A paltry 100MHz increase for a $25 price premium? No thank you!
Quote
https://linustechtips.com/topic/575893-help-pleeeaaaase/#findComment-7536325
it's not worth it then. thanks!
CPU-Boss (not reliable at all) shows little improvement in FPS, but the R9 390 is so powerful anyway that it really wont matter......
https://linustechtips.com/topic/575893-help-pleeeaaaase/#findComment-7536326
i'd overclock a 6500
Build Name:
Anton
CPU: I7 4790K
GPU: ZOTAC RTX 2060 SUPER AMP EXTREME
RAM: 16GB 1600MHZ
MOBO: MSI H81M-E33
CASE: COOLER MASTER N300
PSU: THERMALTAKE 600 WATT
STORAGE: TOTAL 6.5TB, 512GB SAMSUNG 850 PRO BOOT DRIVE, 2TB HDD 1, 2TB HDD 2, 2TB WESTERN DIGITAL USB 3.0 BACKUP DRIVE
- CRACK!
https://linustechtips.com/topic/575893-help-pleeeaaaase/#findComment-7536369
can you do it with a b150?
yep perfectly fine
Build Name:
Anton
CPU: I7 4790K
RAM: 16GB 1600MHZ
MOBO: MSI H81M-E33
- CRACK!
https://linustechtips.com/topic/575893-help-pleeeaaaase/#findComment-7536461
okay thanks! I'll look into it in the future
np
Build Name:
Anton
CPU: I7 4790K
RAM: 16GB 1600MHZ
MOBO: MSI H81M-E33
- CRACK!
https://linustechtips.com/topic/575893-help-pleeeaaaase/#findComment-7536476
