http://imgur.com/gxId9Hr
WILL UPDATE WHEN CPU ARRIVES:
Wanted a 1080p gaming machine (also was done with my shitty laptop), so I decided to build my own computer. The build would have costed about 800 if not for this dude on Craigslist that was selling a 660ti for $60 (was going to get the 380), so that saved me a ton of money, for still pretty good performance. Processor and OS are arriving on the 7th-9th so it TECHNICALLY isn't done yet, but this is my thread and I can do what I want.
http://pcpartpicker.com/p/NhyKFT
https://linustechtips.com/topic/575809-first-pc-build/
Okay.
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
https://linustechtips.com/topic/575809-first-pc-build/#findComment-7535511
Just now, Mkander99 said:
yeah you better agree
There are millions of threads, you can have your own if you want it.
Stille (Desktop)
Evoo Gaming 15"
https://linustechtips.com/topic/575809-first-pc-build/#findComment-7535523
1 minute ago, Mkander99 said:
thanks, a lot of people were getting on my case about getting skylake, with a 660ti, but its like in the middle of a 950 and a 960 so its still a pretty capable card
honestly if i was choosing between a new 380 and a 660ti for $60, I'd take it
https://linustechtips.com/topic/575809-first-pc-build/#findComment-7535531
I would go two sticks of ram, and get a nicer motherboard if you need help finding one i can find one for you.
also get a nicer case
and that wifi adapter is terrible
I'm always here to help
https://linustechtips.com/topic/575809-first-pc-build/#findComment-7535549
wanted to have the potential to upgrade later, why get something i dont need, and i already bought every component
the case is fine... what is bad about it?
its better than my laptop's wifi card, or a usb adapter. anyways my wifi sucks anyway so i dont need a good card
https://linustechtips.com/topic/575809-first-pc-build/#findComment-7535556
ok just noticed it
The case is from some no-name brand and it seems like you cheaped out on the case and ram and motherboard to fit in a core i5, you should of gone amd or core i3 and not cheaped on on the things i stated
ok
https://linustechtips.com/topic/575809-first-pc-build/#findComment-7535559
yeah diypc isnt well known but the case is better than my friends Cooler Master Elite 130, ram doesnt really matter... and motherboard is what i need, and not bad. i need a quadcore for what im going to be playing, not some hyperthreaded "quadcore", and i need quicksync so no AMD
https://linustechtips.com/topic/575809-first-pc-build/#findComment-7535583
ok whatever works for you I was just saying what i would do
https://linustechtips.com/topic/575809-first-pc-build/#findComment-7538936
