Motherboard doesn't have enough fan
Solved by Allshevski,
7 hours ago, hjalli3 said:oh then this this is solved because I got a 3-pin to molex adapter with the fans that I will just use to plug in to the psu.
one final question though, if I get a fan controller will I be able to control the speed of any fan or do I need a fan that is compatible with fan controllers?
To control your fans you have to connect them to your motherboard. If the header you use has DC control, then great, you will be able to control the fans. But On some motherboards it's only 3 pin CPU and PWM headers. If you buy a fan controller, any fan will work fine.
