Welcome to my next Build (My NZXT Dream):
  • Budget: Well 3 grand not including water-cooling parts, purchasing in United States in Iowa.
  • Uses: Gaming, encoding movies/music, ripping movies/music, web surfing, schooling, professional use, and overclocking (duh), 24/7 steaming to my PS4's, My OnePlus One, laptop, & two tablets.
  • White & Black Theme
  • Enjoy.
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor  ($351.98 @ Newegg)
Thermal Compound: Arctic Silver 5 High-Density Polysynthetic Silver 3.5g Thermal Paste  ($6.99 @ Newegg)
Motherboard: MSI X99A SLI KRAIT EDITION ATX LGA2011-3 Motherboard  ($273.82 @ Newegg)
Memory: Kingston HyperX Fury Black 32GB (4 x 8GB) DDR4-2400 Memory  ($149.99 @ Newegg)
Storage: Samsung 850 EVO-Series 1TB 2.5" Solid State Drive  ($291.99 @ Amazon)
Storage: Seagate Barracuda 3TB 3.5" 7200RPM Internal Hard Drive  ($94.99 @ Newegg)
Storage: Toshiba X300 4TB 3.5" 7200RPM Internal Hard Drive  ($124.99 @ Micro Center)
Video Card: Asus GeForce GTX 980 Ti 6GB STRIX Video Card  ($683.98 @ Newegg)
Case: NZXT Phantom 820 (White) ATX Full Tower Case  ($187.99 @ Amazon)
Power Supply: EVGA SuperNOVA P2 850W 80+ Platinum Certified Fully-Modular ATX Power Supply  ($129.99 @ Newegg)
Optical Drive: LG WH14NS40 Blu-Ray/DVD/CD Writer  ($50.70 @ Amazon)
Operating System: Microsoft Windows 10 Home OEM (64-bit)  (Purchased For $86.86)
Monitor: Asus MG279Q 144Hz 27.0" Monitor  ($559.99 @ Micro Center)
Other:  Rosewill 90 Piece Professional Computer Tool Kit Components Other RTK-090 Black  ($38.01)
Other:  Microsoft Xbox 360 Wired Controller for Windows & Xbox 360 Console  ($27.99)
Other: Ajazz The Dark Knight USB Gaming Keyboard Mouse Pad Combo Set & 7 LED Colors 2400DPI 6 Buttons USB Gaming Mouse (Purchased For $68.99)
Other: ORICO HF9US-2P-BK 9 Port USB Hubs & 2 Charging Port with Power Switch and Premium 12V 2.5A Power Adapter – Black (Purchased For $15.99)
Other: Coboc CY-CAT7-20- Black  20 ft. 26AWG Snagless Cat 7 Black Color 600MHz SSTP(PIMF) Shielded Ethernet Stranded Copper Patch cord /Molded Network LAN Cable (Purchased For $8.09)
Other:  NZXT IU01 Internal USB Expansion (Black)  (Purchased For $18.49)
Other:      EK Supremacy EVO Universal CPU Liquid Cooling Block - Acetal + Nickel (EK-Supremacy EVO - Acetal+Nickel) ($79.99)
Other: EK GeForce GTX 980 Strix Backplate - Black (FC980 GTX Strix Backplate - Black) ($35.99)
Other: EK GeForce GTX 980 Strix Full Coverage Water Block - Acetal + Nickel (EK-FC980 GTX Strix - Acetal+Nickel) ($131.99)
Other: EK D5 X-Top Pump Top w/ D5 Vario Pump - Black Acetal (EK-XTOP D5 Vario - Acetal (incl. pump)) ($144.97)
Other: Koolance G1/4" Brass Inline Drain Valve Fitting - 4 Port (VLV-XUTX4B) ($11.99)
Other: EK G1/4 Thread High Flow Barb - 12mm (1/2") x 22 ($65.78)
Other: Tygon B-44-4X 1/2" ID (5/8" OD) - "Non-Porous" Smooth Tubing (5 Ft.) ($11.25)
Other: EK Dual Bay SPIN Reservoir w/ Flow Meter - Acetal Black CSQ (w/ EK-DBAY Aluminum Bezel) ($71.98)
Other: EK Ekoolant Pastel Concentrate 250mL - Pastel White ($21.99)
Other: Monsoon .999 Fine Silver Bullet Antimicrobial In-Line Bundle Pack (Silver Everything) ($22.99)
Other: XSPC 120mm Radiator Gasket - 3mm ($2.50)
Other: XSPC 3 x 120mm Radiator Gasket - 3mm ($4.00)
Other: EK High Performance CoolStream 360 PE Series Liquid Cooling Radiator (EK-CoolStream PE 360 (Triple)) ($75.99)
Other: EK High Performance CoolStream 120 PE Series Liquid Cooling Radiator (EK-CoolStream PE 120 (Single)) ($46.99)
Other: Bitspower Quick-Disconnect Male w/ Inner G1/4 - Silver (BP-QDMIG14) (Qty. 8) ($155.60)
Other: Noiseblocker NB-BlackSilentPro PL-2 120mm x 25mm Ultra Quiet Fan - 1400 RPM - 20 dBA (+Sleeving) ($127.72)
Other: CableMod E-Series G2 / P2 Cable Kit - Black/White (+ Free Gift - Cable Combs) ($89.95)
Total: $4263.49
Generated by PCPartPicker 2016-04-01 10:52 EDT-0400
Thanks In advance.
If you've previously won the build off please pm me so we can get something worked out.
2 minutes ago, Redicat said:
Spends over 4K on super custom watercooled beast has PS4 to stream at? xD
Damn straight. Eventually once our wedding gets done and we get the car paid off I want to get a 4k HDTV and stream it via a HTPC, but until then you damn right I'm streaming it via Plex to 2xPS4's. :D Any suggestions tho?
