help
Go to solution Solved by KNarild,
1 minute ago, Moonzy said:
they have totally different connector for the motherboard lol
usb3 =  blue, usb2 = the small block connector
  Reveal hidden contents
500x375px-LL-a6dccaca_nzxt-aperture-m-co
oh well you saved me there! ty a lot
hey first time pc builder here, im using an old server case that has usb 1 conector annd ONE usb 2 and an optical drive i want to replace the 5.25 optical drive with this and i wonder if it is compitable with the mother board ty for any help :)
Motherboard: https://www.asus.com/us/Motherboards/Z170-DELUXE/
5.25 usb  :
http://www.ebay.co.uk/itm/2x-USB-3-0-and-4x-USB-2-0-Hub-plus-2-1A-Charge-Port-5-25-Front-Panel-with-Cable/331589622178?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D35391%26meid%3D02138d34a8964ddfb6a50a858cd38c27%26pid%3D100005%26rk%3D1%26rkt%3D6%26sd%3D181924320983
case for those interested: ( the old motherboard is still installed )
https://linustechtips.com/topic/574683-help/
i think you'll be left with one usb 3.0 plug after you plug all these connectors in
assuming your case doesnt have IO lol
wat is 1O?
if you men gen one usb it does actually, im using this one as a temporary solution untill i can get some more money
https://linustechtips.com/topic/574683-help/#findComment-7524578
1 minute ago, KNarild said:
wat is 1O?
input/output
basically means that the expansion you're getting will hog up 3 usb ports on the motherboard (2 usb2 and 1 usb3)
so your motherboard will have one usb3 port unfilled
so if your case have a usb 3, you can use that remaining port, but you wont have enough usb 2 header if your case needs it
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/574683-help/#findComment-7524598
input/output
i could still use the usb 2 on the usb 3 conectors on the motherboard though?
just with decreased speeds
https://linustechtips.com/topic/574683-help/#findComment-7524613
https://linustechtips.com/topic/574683-help/#findComment-7524628
you know, even if your case comes with usb2 and 3 header, its fine to just not plug them in
its just that they cant be used
https://linustechtips.com/topic/574683-help/#findComment-7524659
