I needed to export a video I was editing for school and I exported it as a .AVI file. Then I wanted to compress it to a .mp4 with hand brake then when I tried this came up.
An Unknown Error has occured.
System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.IO.IOException: There is not enough space on the disk.
   at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
   at System.IO.FileStream.WriteCore(Byte[] buffer, Int32 offset, Int32 count)
   at System.IO.FileStream.FlushWrite(Boolean calledFromFinalizer)
   at System.IO.FileStream.Dispose(Boolean disposing)
   at System.IO.Stream.Close()
   at HandBrake.ApplicationServices.Services.QueueProcessor.BackupQueue(String exportPath) in H:\Development\HandBrake\0.10.x\win\CS\HandBrake.ApplicationServices\Services\QueueProcessor.cs:line 209
   at HandBrake.ApplicationServices.Services.QueueProcessor.GetNextJobForProcessing() in H:\Development\HandBrake\0.10.x\win\CS\HandBrake.ApplicationServices\Services\QueueProcessor.cs:line 277
   at HandBrake.ApplicationServices.Services.QueueProcessor.ProcessNextJob() in H:\Development\HandBrake\0.10.x\win\CS\HandBrake.ApplicationServices\Services\QueueProcessor.cs:line 586
   at HandBrake.ApplicationServices.Services.QueueProcessor.Start(Boolean isClearCompleted) in H:\Development\HandBrake\0.10.x\win\CS\HandBrake.ApplicationServices\Services\QueueProcessor.cs:line 460
   at HandBrakeWPF.ViewModels.MainViewModel.StartEncode() in H:\Development\HandBrake\0.10.x\win\CS\HandBrakeWPF\ViewModels\MainViewModel.cs:line 1447
   --- End of inner exception stack trace ---
   at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor)
   at System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments)
   at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
   at Caliburn.Micro.ActionMessage.<.cctor>b__d(ActionExecutionContext context) in c:\Users\Rob\Documents\CodePlex\caliburnmicro\src\Caliburn.Micro.Silverlight\ActionMessage.cs:line 289
   at Caliburn.Micro.ActionMessage.Invoke(Object eventArgs) in c:\Users\Rob\Documents\CodePlex\caliburnmicro\src\Caliburn.Micro.Silverlight\ActionMessage.cs:line 254
   at System.Windows.Interactivity.TriggerBase.InvokeActions(Object parameter)
   at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
   at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
   at System.Windows.Controls.Primitives.ButtonBase.OnClick()
   at System.Windows.Controls.Button.OnClick()
   at System.Windows.Controls.Primitives.ButtonBase.OnMouseLeftButtonUp(MouseButtonEventArgs e)
   at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
   at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
   at System.Windows.UIElement.ReRaiseEventAs(DependencyObject sender, RoutedEventArgs args, RoutedEvent newEvent)
   at System.Windows.UIElement.OnMouseUpThunk(Object sender, MouseButtonEventArgs e)
   at System.Windows.UIElement.RaiseTrustedEvent(RoutedEventArgs args)
   at System.Windows.Input.InputManager.ProcessStagingArea()
   at System.Windows.Input.InputProviderSite.ReportInput(InputReport inputReport)
   at System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr hwnd, InputMode mode, Int32 timestamp, RawMouseActions actions, Int32 x, Int32 y, Int32 wheel)
   at System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr hwnd, WindowMessage msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
   at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
   at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
https://linustechtips.com/topic/573832-handbrake-converting-problem/
1 minute ago, zMeul said:
check if the target partition has enough space left and also check if it's NTFS; if it's FAT32, it can't handle files larger than 4GB
Yeah I just found out that I didn't have enough space and the hard drive is in NTFS.
