Does anyone know how to setup windows 10 so that I could get playback in two (or more) separate pairs of g930(or similar) headphones at the same time? Would be nice for watching movies on the HTPC without waking up everyone else in the house?
Thanks,
Elliott35
There should be an application called virtual audio cable that should allow you to do this.
|Casual Rig| CPU: i5-6600k |MoBo: ROG Gene  |GPU: Asus 670 Direct CU2 |RAM: RipJaws 2400MHz 2x8GB DDR4 |Heatsink: H100i |Boot Drive: Samsung Evo SSD 240GB|Chassis:BitFenix Prodigy |Peripherals| Keyboard:DasKeyboard, Cherry MX Blue Switches,|Mouse: Corsair M40
|Server Specs| CPU: i7-3770k [OC'd @ 4.1GHz] |MoBo: Sabertooth Z77 |RAM: Corsair Vengeance 1600MHz 2x8GB |Boot Drive: Samsung 840 SSD 128GB|Storage Drive: 4 WD 3TB Red Drives Raid 5 |Chassis:Corsair 600t
As well as downloading virtual audio cable you will need voicemeeter banana. From there you can select your inputs and your outputs. There will be 3 outputs so you can select where you want your sound to go.
[Case Mod] Operation: The Division --- > Here
[CUSTOM WATER COOLED TABLE] Project: Ravage ---> Here
-== QUOTE ME IN YOUR REPLY IF YOU WANT ME TO RESPOND ==-
