i want to mount my motherboard in a shelf. i want to mount it vertically so i was looking for something to use to mount the motherboard to the wood.
i found a few items but am not sure which is best or if there is something like a motherboard frame that has screw holes to mount a motherboard bracket onto the self then the motherboard to the bracket.
here what i have found so far:
the tray / 3rd link is to much looking to not spend much on this
1.http://www.amazon.com/dp/B0026GUEN4/ref=biss_dp_t_asn
2.https://www.fastenal.com/web/products/details/0125610
3.http://www.amazon.com/CaseLabs-Motherboard-Assembly-Merlin-Black/dp/B01BFNW4QI/ref=sr_1_8?ie=UTF8&qid=1459286627&sr=8-8&keywords=motherboard+tray
CPUi7 5820k
MotherboardAsRock x99 extreme4
RAM16gb (4x4gb)
GPUgtx 980ti zotac amp
CaseNZXT Phantom Windowed Edition Black
Storage2tb hdd and Crucial MX 200 250 gb SSD
PSU750 watt cool master
Display(s)2 monitors both 1080p
Cooling80mm water cooling for cpu
KeyboardRazer Ultimate 2013 mechanical
KeyboardMouseRazer Hex Naga (green gloss)
Operating System windows 10
https://linustechtips.com/topic/573658-help-with-mounting-mobo/
The Merlin Black seems to be the way to go, drill holes for it if you need to and go from there
 Crust : Intel Core i5 4690K @ 4.4Ghz 1.45v  |  MotherboardMSI Z97 MPower  |  Fruity FillingMSI GTX 960 Armor 2Way-SLI |  CoolingNoctua NH-D15  |  RAM : 16GB Corsair Vengeance 1600Mhz | Storage : 2xSamsung 840 EVO 500GB SSDs Raid-0  |  Power Supply : Seasonic X-Series 1250W 80+Gold  |  Monitor : Dell U2713HM 27" 60Hz 1440p  |
https://linustechtips.com/topic/573658-help-with-mounting-mobo/#findComment-7514166
can i litterally just mount it with extra long screws since im not using any pcie cards
CPUi7 5820k
RAM16gb (4x4gb)
https://linustechtips.com/topic/573658-help-with-mounting-mobo/#findComment-7514465
