Can i use my Antenna for my Usb WiFi Adapter ?
Solved by Stefan1024,
The connector standard is called SMA. You can buy an adapter. If you do something DIY you will mess up the impedance and cause problems for the receiver.
Also all powered USB hubs do regenerate the USB signal.
Featured Topics
realfireguy ·
Posted in Graphics Cards0 -
Winterlight ·
Posted in Phones and Tablets0 -
3
ineedhelp.2145 ·
Posted in General Discussion0 -
atxcyclist ·
Posted in Home Theater Equipment1 -
1
2
3
play_circle_filled
Latest From Linus Tech Tips:
I Am Not Buying A Super Computer - WAN Show May 3, 2024
