Hey guys basically I have a really old computer and I have replaced the hdd threw it in the bin and put a ssd inside it, I have installed Windows somehow and tryer reinstalling it 5-10 times and it's constantly a battle to install it, once I have installed it Windows now is giving me 1000 problems such as when I want to instal something it doesn't go anywhere sometimes it works sometimes it doesn't sometimes it would randomly freeze I can't open programs such as on screen keyboard and disk cleanup etc and I feel like it's missing slot of files  Windows update doesn't work eaither and it's just being so hard to work with I don't know what's going on? Help please?
https://linustechtips.com/topic/573028-help-computer-issue/
3 minutes ago, nickspacemonkey said:
Which Windows?
How old a PC, any specs?
Which SSD?
Also wrong section.
Windows 7 ultimate
irs a amd 145 single core
its got old motherboard too and ssd is 120gb Kingston ssd but it was working fine before the reinstallsfion
https://linustechtips.com/topic/573028-help-computer-issue/#findComment-7507267
Well the first thought is a bad .iso
Next I would try it with the hdd instead and just wipe it first
The next thing being try a live OS or a system care/fix OS
Can the cpu and ram handle the OS you tried? is it x32 or x64?
4 minutes ago, nickspacemonkey said:
Also wrong section.
Try moving to troubleshooting
                   _/ V\
    ______|   __/_/| |
   /_______\______}\__}
[I5-12600k | 32gb DDR5 6000 | RTX5070 | 2x1tb M.2]
[Ryzen 5 1600 | 16gb DDR4 3200 | GTX1030 | 4x 8tb HDD]
https://linustechtips.com/topic/573028-help-computer-issue/#findComment-7507271
2 minutes ago, donboki said:
Windows 7 ultimate
no just no xD but if you must use that cpu I assume you have 2gb of ram? so try win7 home basic or even Zorin 9 lite
I would strongly recommend zorin
If you actually has win7 working fine before then I go back to a bad install or most likely a corrupt iso
                   _/ V\
    ______|   __/_/| |
https://linustechtips.com/topic/573028-help-computer-issue/#findComment-7507276
