Hey guys.i am building a new pc and this seems to be the place to ask help this is the configuration i have in mind:-
gpu:-nvedia gtx 970
if there is a better card for the same price do tell.
cpu:-intel i5
there are multiple versions of this card (4500k 6600k etc)i am confused which one should i buy.
motherboard:-
MSI 970 Gaming Motherboard it was recommended by a friend.it costs about 9000 rupees that is 134$ parts are little expensive in india
if there is a better alternative to this what should i look for while buying a motherboard
ram now this is interisting there is ddr3 and ddr4 ram available and both are by cosair but i dont know if it will be supported by the parts explain this please.
psu
i dont know how much power is needed for this i think 650W psu would be sufficient
storage samsung ssd 250 gb and 1 tb hard drive
i plan on overclocking later and when i do that ill get better cooling solution for now stock cooling should be fine.yes this is for gaming.
all the help is greatly appreciated
https://linustechtips.com/topic/572985-build-help/
gpu:-nvedia gtx 970
cpu:-intel i5
motherboard:-
psu
Have you got a budget in mind? I can tell you what you can get then, as the different parts vary in price considerably
https://linustechtips.com/topic/572985-build-help/#findComment-7506786
16 minutes ago, morpheus2658 said:
1200$ india
Prices are very different when it comes to India. Can you get your parts from the US, or are you going to buy them in India? Because $1200 will only get you about $700 worth of parts there, maybe less.
i5 12600KF | Zotac RTX 4080 Gaming trinity | Team Vulcan 2x16GB DDR4 3600 | ASRock Z690M-ITX/ac | WD Black SN850x 2TB
Cooler Master NR200P v2 | ID Cooling Zoomflow 280 XT | SeaSonic Focus SGX-750 | Thermalright 2x140mm + 2x120mm aRGB
LG C2 OLED 48" 120hz | Epomaker TH80 (Gateron Yellow) | Logitech MX Master 3 | Koss Porta Pro Comm
https://linustechtips.com/topic/572985-build-help/#findComment-7506899
yes i know but i am not allowed to order them online.i will be buying them from a nehru place delhi
https://linustechtips.com/topic/572985-build-help/#findComment-7506907
Yeah, Nehru Place prices are much higher, often almost double the overseas MRP. Try to wait until you can have someone bring them, and buy the case and maybe the power supply. Don't waste your money at Nehru Place. Even heavily used computer parts in Delhi cost more than they do brand new in the US.
https://linustechtips.com/topic/572985-build-help/#findComment-7506913
1 minute ago, Supercian411 said:
yes much better and twice and much vram
I mean, yes, it would work if Indian vendors had AMD video cards in stock.
Here is his pricing and availability. This is a list of all available parts from the main vendor at the market he's looking at. http://www.costtocost.in/list/pricelist.pdf
@morpheus2658 give them your exact budget in rupees, as that's what the catalogue is organized in.
https://linustechtips.com/topic/572985-build-help/#findComment-7506938
well i given my condition i can only purchase the parts from a shop from ambala chandigarh or delhi.i live in a small town and my parents wont allow me to order online.
https://linustechtips.com/topic/572985-build-help/#findComment-7506942
I already posted this. This is the catalogue of Nehru Place's main vendor. Give us your budget in rupees and we'll work out a build based on these parts. Get the power supply on Flipkart, though. A Seasonic S12ii for 520-600w for Rs. 6,000
https://linustechtips.com/topic/572985-build-help/#findComment-7506946
I have never been to asia and have no idea what the shops are like
https://linustechtips.com/topic/572985-build-help/#findComment-7506947
ok
https://linustechtips.com/topic/572985-build-help/#findComment-7506951
Well, he's only going to be able to buy his parts from New Delhi, India, which is why I provide a catalogue with price references for the same. If you want to help him put together a build within his budget, you'll likely need to refer to Indian pricing and availability.
https://linustechtips.com/topic/572985-build-help/#findComment-7506955
that pdf is really confusing
https://linustechtips.com/topic/572985-build-help/#findComment-7506958
Welcome to my country. Things here are like that- overpriced, disorganized, and poorly-maintained. Keep in mind that there's a 12% tax on each item on that PDF. Yeah, that's right. You're paying almost $1000 for a 980 Ti.
https://linustechtips.com/topic/572985-build-help/#findComment-7506962
