13 hours ago, Aereldor said:
Welcome to my country. Things here are like that- overpriced, disorganized, and poorly-maintained. Keep in mind that there's a 12% tax on each item on that PDF. Yeah, that's right. You're paying almost $1000 for a 980 Ti.
the tax is included in price or will add up later?
https://linustechtips.com/topic/572985-build-help/page/2/#findComment-7507008
@morpheus2658- I actually managed a decent build using just parts from Cost to Cost.
Cost to cost reference build- (80,000 budget).
  • CPU- Intel Core i5 6600- Rs. 15,795
  • Motherboard- Asus H170M PLUS- Rs. 9,640
  • RAM- GSkilll 8GB DDR4- Rs. 2,695
  • GPU- Zotac GTX 970- Rs 23,595
  • HDD- 1TB 'SATA WD' (probably Caviar Blue)- Rs 3.190.
  • Case- Corsair SPEC-01- Rs 3,490
  • Power Supply (FLIPKART)- Seasonic S12II 520- Rs 5,500
  • Monitor- BenQ GL 2460 HM- Rs. 9,295
Total (no tax)- Rs. 71,200
12% Tax- Rs 8,544
TOTAL AFTER TAX- Rs. 79744
i5 12600KF | Zotac RTX 4080 Gaming trinity | Team Vulcan 2x16GB DDR4 3600 | ASRock Z690M-ITX/ac | WD Black SN850x 2TB
Cooler Master NR200P v2 | ID Cooling Zoomflow 280 XT | SeaSonic Focus SGX-750 | Thermalright 2x140mm + 2x120mm aRGB
LG C2 OLED 48" 120hz | Epomaker TH80 (Gateron Yellow) | Logitech MX Master 3 | Koss Porta Pro Comm
https://linustechtips.com/topic/572985-build-help/page/2/#findComment-7507077
Look at the build I put together for you based on parts from Cost to Cost and the power supply from Flipkart. There shouldn't be any extra tax on the power supply, but there will be a small delivery fee, so maybe 200-300 rupees less than the final build.
https://linustechtips.com/topic/572985-build-help/page/2/#findComment-7507081
  • CPU- Intel Core i5 600- Rs. 15,795
12% Tax- Rs 8,544
thanks man i think you ment to type i5 6600 instead of 600
https://linustechtips.com/topic/572985-build-help/page/2/#findComment-7507084
ok
https://linustechtips.com/topic/572985-build-help/page/2/#findComment-7507091
Yeah, my bad. All things considered, this is a pretty nice build. Indian prices are terrible, but this will last you more than a few years gaming at 1080p.
https://linustechtips.com/topic/572985-build-help/page/2/#findComment-7507093
i wish we got better prices here but guess we gotta deal with what we have.
https://linustechtips.com/topic/572985-build-help/page/2/#findComment-7507099
Honestly, it isn't as bad as I thought it would be. Here's the exact same build on PCPartPicker.
CPU: Intel Core i5-6600 3.3GHz Quad-Core Processor  ($215.99 @ SuperBiiz)
Motherboard: Asus H170M-PLUS Micro ATX LGA1151 Motherboard  ($99.95 @ Amazon)
Memory: G.Skill NT Series 8GB (1 x 8GB) DDR4-2400 Memory  ($29.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($48.85 @ OutletPC)
Video Card: Zotac GeForce GTX 970 4GB Video Card  ($309.88 @ OutletPC)
Case: Corsair SPEC-01 RED ATX Mid Tower Case  ($37.99 @ Micro Center)
Power Supply: SeaSonic S12II 520W 80+ Bronze Certified ATX Power Supply  ($55.98 @ Newegg)
Monitor: BenQ GL2460HM 60Hz 24.0" Monitor  ($139.00 @ Amazon)
Total: $937.63
Generated by PCPartPicker 2016-03-28 13:17 EDT-0400
It costs about 25% less, but I was expecting the price difference to be a lot higher.
https://linustechtips.com/topic/572985-build-help/page/2/#findComment-7507109
Total: $937.63
thats good
https://linustechtips.com/topic/572985-build-help/page/2/#findComment-7507116
Oh, since you live in India- here's a little tip.
Cherry MX has a factory in India and a joint venture with TVS electronics that lets them make really cheap Cherry MX keyboards. The cheapest ones cost like Rs. 5,500 minimum in the US. However, the Indian Cherry MX Blue keyboard is half the price.
http://www.amazon.in/TVS-GOLD-USB-BHARAT-KEYBOARD/dp/B00U126ZGA?tag=googinhydr18418-21
I have one of these, and it's a dream.
https://linustechtips.com/topic/572985-build-help/page/2/#findComment-7507134
thank you all for taking your time to help me.you have my gratitude.
Cheers, mate. I'm not much of a patriot or a 'country and community' guy, but PC enthusiasts in India have to help each other out, especially when the market is stacked against us.
https://linustechtips.com/topic/572985-build-help/page/2/#findComment-7507143
thanks ill look into it
https://linustechtips.com/topic/572985-build-help/page/2/#findComment-7507146
