So i bought a samsung 42 inch 4k curved tv and it is very blurry when watching tv! any suggestions on what to do?
I use a freesat box if that makes any difference
MY RIG
I5 6600k
16gb Corsair vengeance 2666mhz
MSI Gaming X 1070
WD blue 2tb
samsung 850 evo 250gb
EVGA supernova G2 650w
https://linustechtips.com/topic/572555-4k-tv-problem/
what resolution is he "freesat box" pushing to the 4k tv? its pointless if its pushing 720p to a 4k panel, it'll just be 720p
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/572555-4k-tv-problem/#findComment-7502588
is upscaling enabled?
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/572555-4k-tv-problem/#findComment-7502591
I belive it goes between 560p and 1080p depending on what im watching
MY RIG
I5 6600k
MSI Gaming X 1070
WD blue 2tb
https://linustechtips.com/topic/572555-4k-tv-problem/#findComment-7502594
well, it wont improve quality unless you're playing 4k contents on it
also, im assuming you're using hdmi?
https://linustechtips.com/topic/572555-4k-tv-problem/#findComment-7502605
Yes, but im not talking about not that good im talkig about this
MY RIG
I5 6600k
MSI Gaming X 1070
WD blue 2tb
https://linustechtips.com/topic/572555-4k-tv-problem/#findComment-7502632
Hello?
MY RIG
I5 6600k
MSI Gaming X 1070
WD blue 2tb
https://linustechtips.com/topic/572555-4k-tv-problem/#findComment-7502725
Hello?
soz im watching movie + replying so i might've missed the notification lol
anyway try going through the settings on your tv, i dont know specifically what you should tweak though
also check if your box is outputting the optimal resolution (1080p or something) to the tv instead of potato resolution
https://linustechtips.com/topic/572555-4k-tv-problem/#findComment-7502745
