Does this tiny 8-pin difference matter?
Go to solution Solved by zMeul,
1 minute ago, Zomboooooo said:
While this is the other end of the cable. Weird~~~~~right?
not weird at all
those are correct, those are PCIe power for graphics cards
This picture was took from my  STRIX-GTX970 manual. Does it matter which cable I plug in? The picture certainly shows that the second one is the wrong one but for some reason I can still plug in a wrong square-pin-pattern cable. I'm so confused....do I need the "right pattern" cable or not?
https://linustechtips.com/topic/572526-does-this-tiny-8-pin-difference-matter/
Just plug in the one that says "GPU".  It should be a 6+2 cable anyways.
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
Make sure the cable says PCIe on it.  Also make sure its the correct end.  If you have a modular PSU, the PCIe cables could be pretty similar between the power supply end and the PCIe end.  However, it should be clearly labeled.
2500k | Z68-UD3H-B3 | GTX 570 Classified + Accelero Xtreme III | MX 200 250GB + Seagate 500GB | R4 | Seasonic 660W Plattinum | 8GB G Skill | Acer K272HUL + 2 x Dell P2417H, Rosewill dual mount, HP 22bw | Mackie CR3, ATH-M50X | DAS Keyboard | Mobile: X1 Carbon, Nexus 6P, LG G3, Samsung S5, Nexus 7 (2013)
4 minutes ago, zMeul said:
one is PCIe power and another is EPS power - don't mess with them if you value your purchase
The PSU end says PCIe indeed, but the other end is labeled VGA and it's the EPS power pin layout you are talking about......................dang....I'm confused
can you post a pic? you're confusing me ...
VGA would be a way to label it but how is EPS ?!?!
what PSU? make and model, maybe we can find a manual and clear it up
the EPS connector has the yellow cable ends on top:
while the PCIe connector has the yellow cables on the bottom:
22 minutes ago, zMeul said:
not weird at all
I just realized.....it's my mistake........let me clear it up. My graphic card needs a connector like the first pic and my cable looks the second pic. There's only 2 squares in the second one. So they are the same?
11 minutes ago, WereCat said:
Those are right cables. PCI-e are 6pin, 6+2pin or 8pin while EPS are 4pin, 4+4pin usualy and 8pin.
Thank you for all your help. But new question.......the 8-pin connector on my mobo looks like 1st pic while the 4+4 pin cable looks like 2nd pic. Are they the same then?
6 hours ago, WereCat said:
yea
did you see my post?
could you answer me this question? I'm still confused....thank you.
Some motherboards only need a 4 pin power connector so the power supply lets you split them in case you do. So just put them together and put it in.... Wait. Now I'm confused the bottom is completely different. What cable is that one one he bottom? See if it fits. I guess don't know if my psu and mobo are like that too? That seems like something is wrong with your psu idk.
--Bailey
http://pcpartpicker.com/list/CwGvWX
CPU: AMD FX-8320 4GHz Motherboard: MSI 970 GAMING ATX AM3+  Memory: G.Skill Ripjaws X 16GB DDR3-1600 Storage: Crucial BX200 240GB SSD Storage: Seagate 1TB 7200RPM HDD
Video Card: MSI GeForce GTX 1060 6GB Case: NZXT Noctis 450 Mid Tower Power Supply: EVGA 600B 600W 80+ ATX
