Processor is running at 1/4 speed under load!!!
Go to solution Solved by snorthd,
Thanks everyone for trying to help. Turn slow mode on my mobo on and off fixed it.
1 minute ago, snorthd said:
My CPU is running at 0.8 ghz under load!! How can I fix this? 0.8GHz.PNG.4edca4aae3ab3a47533cfd7618fef
What temps is it running at?
Try disabling energy saving.
AMD Ryzen R7 1700 (3.8ghz) w/ NH-D14, EVGA RTX 2080 XC (stock), 4*4GB DDR4 3000MT/s RAM, Gigabyte AB350-Gaming-3 MB, CX750M PSU, 1.5TB SDD + 7TB HDD, Phanteks enthoo pro case
 disable any energy saving or some shit. your voltage is also less. it is under clocked. Could be the temps.
Just my jubbled up thoughts
Build
Ryzen 5 1600, Cooler Master Hyper 212 Evo, Gigabyte X470 Gaming 7. TeamGroup Viper 4133mhz 16gb, XFX RX 480 8 GB (1000mhz cause dying), Samsung 850 EVO 250 GB M.2 SSD, An old 1tb 5400 rpm 2.5" HDD, TeamGroup 480gb & Kingston 480gb ssds (May RAID 0), 1TB Western Ditigal HDD, EVGA 750W G2 PSU, Phanteks P400s
----------X-----------X------------
