I done know when this started happening but suddenly my CPU started overheating all the time and it leads to low FPS in a game (fps spikes) and freezing of simple stuff like web browsing or even copying files for a few seconds at a time. my CPU is an i3-4160 and I am using an intel stock cooler with the stock thermal compound. there are 2 case fans, one at the top and back of the case and one at the bottom front which is being blocked by a hard drive and SSD bay with one SSD and one HDD in there. it was running at about 61C while I was writing this with Outlook, Spotify, Skype, Trend micro, f.lux and steam open in the background and it froze about twice. another cause for freezing i have noticed is 100 % cpu usage with also happens alot of the time and also looks to be half the cause for the high temps.
Edited by 220478_1454181592
Intel i3-4160 - Gigabyte GA-Z87-HD3 - Asus GTX 750Ti OC - Corsair CX500M - Samsung 840 EVO 120GB - WD Scorpio Blue 500GB 2.5" - WD Caviar Blue 500GB 3.5" - CoolerMaster Hyper 212x.
https://linustechtips.com/topic/572340-overheating-and-freezing/
Just now, 220478_1454181592 said:
can you check task manager to see whats hogging all the cpu resources?
maybe its time to do a clean install of windows to remove any potential bloatware you have?
meanwhile you can try purchasing thermal compound and do a thermal compound re-application
or just buy a cheap cooler like the 212 evo, it'll drop your cpu's temps by quite a bit
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/572340-overheating-and-freezing/#findComment-7500381
tried checking task manager, don't see anything that's actually using any CPU. my dad is the system admin, I am not an admin and he says no to system restore. I am thinking of buying some thermal compound for $10 (AUD) from my local MSY store. I wont be able to buy a cooler because they are quite expensive here in Australia (I prefer us dollar). although is I was going to get a cooler at all it would be a H80(i) or a 212 Evo.
https://linustechtips.com/topic/572340-overheating-and-freezing/#findComment-7500389
how different is this to the 212 evo? http://www.msy.com.au/cooling/12558-coolermaster-hyper-212x-universal-cpu-cooler.html
https://linustechtips.com/topic/572340-overheating-and-freezing/#findComment-7500418
