my sister thinks it needs a calibration done, but i dont really deal with windows 8 stuff. so im not sure how to do so. she says when moving icons, the mouse pointer is in a different spot than where her finger is. it doesnt do it all the time.
shes had alot of problems with this laptop, but i dont think theres anything wrong with the laptop
https://linustechtips.com/topic/572284-81-windowns-laptop-touch-screen-problem/
Try recalibrating it and see if the problem persists.
From Microsoft's website:
Quote
  1. Swipe in from the right edge of the screen, and then tap Search.
    (If you're using a mouse, point to the lower-right corner of the screen, move the mouse pointer up, and then click Search.)
  2. Enter Calibrate in the search box, and then tap or click Calibrate the screen for pen or touch input to open Tablet PC Settings.
  3. Check that the monitor shown in the Display field matches the screen you want to calibrate.
  4. Tap or click Calibrate, and then follow the on-screen instructions.
http://windows.microsoft.com/en-ca/windows-8/touch-pen-settings-faq
I actually couldn't underclock my 5 year old GPU to make it as slow as a next-gen console.
#pcmasterraceproblems
~Slick
