My friend bought a PC off someone locally and installed two GTX 970's himself with SLI. It worked at first but after a few weeks it stopped. During that period it did get knocked over but he isn't sure when it stopped working.
Could it be the bridge is damaged from the drop? Or the motherboard? the MOBo is Gigabyte z97 UD4H.
He's swapped the cards around, cleaned them out. He's also saying they're running quite hot.
Any ideas?
Thanks
CPU: FX-6300 GPU: Sapphire R9 380X MOBO: Gigabyte 970A-DS3P RAM: Corsair Vengeance 8GB PSU: XFX XTR 550W CASE: Zalman Z11 Plus SSD: Samsung 840 Evo
17 years old, PC Enthusiast for 3. Be gentle with me, I'm only young.
https://linustechtips.com/topic/572024-issue-with-970-sli/
By 'it stopped' does that mean the cards work individually but aren't recognized as SLI?
i7 4790k | MSI Z97S SLI Krait Edition | G.Skill Ripjaws X 16 GB | Samsung 850 EVO 500 GB | 2x Seagate Barracuda 2TB | MSI GTX 970 Twin Frozr V | Fractal Design R4 | EVGA 650W
A gaming PC for your budget: $800 - $1000 - $1500 - $1800 - $2600 - $9001
Remember to quote people if you want them to see your reply!
https://linustechtips.com/topic/572024-issue-with-970-sli/#findComment-7497792
Yeah, they work on their own
https://linustechtips.com/topic/572024-issue-with-970-sli/#findComment-7497802
3 minutes ago, Senzelian said:
What exactly stopped working?
Is he not able to enable SLI?
Does the driver crash or the PC shutdown if SLI is enabled?
Does the problem only happen while the graphics cards are under load?
Only one works when they're both in
https://linustechtips.com/topic/572024-issue-with-970-sli/#findComment-7497818
I recommend to uninstall drivers by using the Display Driver Uninstaller (http://www.guru3d.com/files-details/display-driver-uninstaller-download.html).
Then he should download and install the latest drivers from NVidia (http://www.nvidia.com/Download/index.aspx)
Make sure SLI is enabled in die NVidia control panel (Right click on desktop -> Nvidia Control Panel -> SLI, Sorround, PhysX)
Also make sure the SLI bridge is fitted correctly before turning the system on.
If all of that doesn't help, then there might be a problem with his motherboard or graphics cards. I could be a problem with his PSU, but I don't think that this is the case.
https://linustechtips.com/topic/572024-issue-with-970-sli/#findComment-7497848
Okay, will get him to try this, thank you
https://linustechtips.com/topic/572024-issue-with-970-sli/#findComment-7497850
some troubleshooting steps:
- one card in the first x16 slot (test both cards)
- one card in the second x16 slot (test both cards again)
- both cards in place without sli bridge (test if both cards output to a monitor)
- drop sli bridge in (test if both output again)
- test enabling SLI in the drivers
- DDU/reinstall drivers and repeat.
https://linustechtips.com/topic/572024-issue-with-970-sli/#findComment-7497855
The fun of troubleshooting... :P
https://linustechtips.com/topic/572024-issue-with-970-sli/#findComment-7497864
jeea, trust me, i know. i'm 3 weeks in troubleshooting my main monitor reacting to differences in its surrounding.
- temperature/aitrflow
- gpu temp
- wall power variations
https://linustechtips.com/topic/572024-issue-with-970-sli/#findComment-7497871
- gpu temp
Must be a Samsung then. :D
Sorry, I'm a LG fanboy :P
https://linustechtips.com/topic/572024-issue-with-970-sli/#findComment-7497877
A Dell? o.O
That's probably the last I would expect to have such problems.
well, its doing perfect, until the voltmeter plugged into my wall permanently (for..reasons...) starts jolting around agressively.
https://linustechtips.com/topic/572024-issue-with-970-sli/#findComment-7497900
He's tried them both in the second slot now and neither work in there. Assuming that slot is broken.
Will this mobo be a fine replacement?
https://uk.pcpartpicker.com/part/msi-motherboard-z97sslikraitedition
https://linustechtips.com/topic/572024-issue-with-970-sli/#findComment-7497919
Well, that was faster than I expected.
The MSI Krait boards are pretty solid. I bought one for a friend of mine and we got is 4790K to 4.7 Ghz stable. So I can only recommend it :)
https://linustechtips.com/topic/572024-issue-with-970-sli/#findComment-7497931
Yeah, didn't realise he hadn't tried that so got him straight on it. He's ordering the new one now. Hopefully that'll solve the problem
https://linustechtips.com/topic/572024-issue-with-970-sli/#findComment-7497936
I hope so, too.
It's really annoying when SLI isn't working. I know that myself all too well. :P
He should try out if it works outside of his case, before he puts everything together. Imagine he assembles the whole thing and at the end it doesn't work.
https://linustechtips.com/topic/572024-issue-with-970-sli/#findComment-7497974
