Hi there,
I recently built my first own PC, this one: https://pcpartpicker.com/b/DdyfrH
Now I wanted to do a CPU stress test on my Xeon E3-1231v3, to see how hot it would become, but I saw something strange.
After running Aida64 for about 10 minutes, the hottest the CPU had been was 52C, and it was going around 50C.
I don't have a very special cooler, a budget Cryorig H7, so I was expecting some high temps but I got something very different.
Now I don't know if I should be happy or be worried, everything else on the PC is smooth like butter.
What should I do?
https://linustechtips.com/topic/571833-cpu-not-above-50c/
thats about right. nothing to worry about. aida64 doesnt get hard on your cpu compared to other stresstests. and your ambient temp is quite low, its fine.
IF YOU WANT ME TO REPLY TO YOU, QUOTE MY POST.
Fire Strike Score
5820K @ 4.8GHZ - 1.25v / Uncore @ 4.5GHZ - 1.2v / 3000MHZ G.skill 32GB Quad Channel / Asus Rampage V Extreme / 950 Pro Nvme / Sound Blaster ZxR  / 980 TI / Windows 7
https://linustechtips.com/topic/571833-cpu-not-above-50c/#findComment-7495946
6 minutes ago, iBasW said:
What should I do?
nothing tbh.
As long as your cpu maxes out during aida64 and your performance is also normal (maybe try cinebench) you are fine, i can give you a score from my xeon if that helps you
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
https://linustechtips.com/topic/571833-cpu-not-above-50c/#findComment-7495952
is personally use realbench and hwbot x265 benchmark.
Fire Strike Score
https://linustechtips.com/topic/571833-cpu-not-above-50c/#findComment-7495959
