I'm planning to build a PC myself so im doing this so maybe you guys can find a Bottleneck or FeedBack!
My buget is €1.450 and yes, you already guessed it it's Europe!
The System
Case: Coolermaster Mastercase Pro 5 Price:  137,-
CPU: Intel Core I5 6600K Price: 259,-
MotherBoard: MSI Z170A GAMING M5 Price: €174,90
GPU: EVGA GTX 970 4GB FTW+ with ACX 2.0+ Price: €424,-
CPU Cooler: Dark Rock Pro 3 Price: €79,90
RAM: Corsair Vengeance DDR4-2400 16GB Price: 76,90
Storage:
SSD: Kingston HyperX Fury 120GB (For OS) Price: €46,99
HDD: Seagate Barracuda 1TB Price: €49,99
Power Supply: CoolerMaster V750S Price: €84,85
OS: Windows 10 Home 64Bit (I don't know where to buy a windows key from since it's really expensive at the Netherlands)
Keyboard/Mouse/Monitor:
Keyboard: CM Storm Trigger Z Price: €146,29
Mouse: Razer Taipan (Already Have)
Monitor: LG 24MB37PY (Already Have)
Every thing combined costs 1.479,82
If there are possible bottlenecks please tell me and if there is a better component i can use.
as example other DDR4 ram for a lower price please reply
This was my post and have a nice day.
Good Bye!
https://linustechtips.com/topic/571434-updated-planning-for-build/
You should go for a cheaper mobo, you don't really need a 170eu mobo in a mid end system, with the money you save from the mobo i'd go for a gtx970 or a r9 390 also go for a evga g2 psu's or corsair ax/rm/rmx series. The keyboard is personal preference but you can get a corsair rgb strafe for around the same price and it has rgb and a wrist rest aswell.
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
Just now, stealth80 said:
kinguin/g2a/reddit sells msdn keys which aren't supporting Microsoft in anyway and they are obtained by exploiting microsofts system, so you might aswell pirate it.
http://uk.pcpartpicker.com/p/GtWQ8d / http://uk.pcpartpicker.com/p/GtWQ8d/by_merchant/
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  (£194.33 @ Aria PC)
CPU Cooler: Corsair H60 54.0 CFM Liquid CPU Cooler  (£60.05 @ Amazon UK)
Motherboard: MSI Z170A GAMING M5 ATX LGA1151 Motherboard  (£139.99 @ Amazon UK)
Memory: Kingston HyperX Fury Black 16GB (2 x 8GB) DDR4-2133 Memory  (£56.99 @ Amazon UK)
Storage: Kingston SSDNow V300 Series 240GB 2.5" Solid State Drive  (£58.97 @ Dabs)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (£40.12 @ Amazon UK)
Video Card: MSI GeForce GTX 970 4GB Twin Frozr V Video Card  (£268.98 @ Amazon UK)
Case: Corsair SPEC-02 ATX Mid Tower Case  (£54.99 @ Amazon UK)
Power Supply: Corsair CX 750W 80+ Bronze Certified Semi-Modular ATX Power Supply  (£69.74 @ Amazon UK)
Operating System: Microsoft Windows 10 Home OEM (64-bit)  (£74.99 @ Ebuyer)
Total: £1019.15
Generated by PCPartPicker 2016-03-25 18:47 GMT+0000
I'm not sure of the exact conversion but I think this should be within your target range.
You really are dropping too much on a MB. Budget boards produce the same performance minus some fancy features.
[CPU: 4.7ghz I5 6600k] [MBAsus Z170 Pro G] [RAM: G.Skill 2400 16GB(2x8)]
[GPU: MSI Twin Frozr GTX 970] [PSU: XFX Pro 850W] [Cooler: Hyper 212 Evo]
[Storage: 500GB WD HDD / 128GB SanDisk SSD ] [Case: DeepCool Tessaract]
[Keyboard: AZIO MGK1] [Mouse: Logitech G303] [Monitor: 2 x Acer 23" 1080p IPS]
My buget is 1.400 and yes, you already guessed it it's Europe!
The System
Case: Coolermaster Mastercase Pro 5 Price: €149,-
GPU: EVGA GTX 960 2GB FTW with ACX 2.0+ Price: €210,50
Storage:
HDD: WD Se 1TB Price: €91,90
Every thing combined costs 1.320,20
Good Bye!
You can get a lot more PC for your money, especially considering the % of your budget you are using on motherboard, keyboard and case
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor  (€388.95 @ Mindfactory)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  (€35.47 @ Amazon Deutschland)
Motherboard: ASRock X99 Extreme4 ATX LGA2011-3 Motherboard  (€208.98 @ Mindfactory)
Memory: G.Skill Ripjaws Series 16GB (4 x 4GB) DDR4-2400 Memory  (€81.84 @ Mindfactory)
Storage: Kingston HyperX Fury 120GB 2.5" Solid State Drive  (€44.13 @ Amazon Deutschland)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  (€54.23 @ Mindfactory)
Video Card: PowerColor Radeon R9 390 8GB PCS+ Video Card  (€309.00 @ Mindfactory)
Case: Fractal Design Define R4 (Black Pearl) ATX Mid Tower Case  (€88.75 @ Amazon Deutschland)
Power Supply: EVGA SuperNOVA NEX 750W 80+ Bronze Certified Semi-Modular ATX Power Supply  (€99.31 @ Amazon Deutschland)
Keyboard: Logitech K480 Bluetooth Wireless Slim Keyboard  (€49.95 @ Amazon Deutschland)
Total: €1360.61
Generated by PCPartPicker 2016-03-25 19:50 CET+0100
Ryzen Ram Guide
and the point is?
Ryzen Ram Guide
7 minutes ago, Becausei'mBatman said:
if you're buying a key from reddit/g2a/kinguin might aswell pirate it.
how so? I will get no real support from pirating and oh ye, its illegal and against the forums CoC ..... so no, that isn't a point at all
Ryzen Ram Guide
exploiting msdn is also against microsoft tos, and you don't support microsoft by doing so.
Total: €1360.61
Hello, strealth80
Thank you for your post, I've looked into all of the components and decided your HDD is better in price and performence thanks, since I will be doing gaming no video editing or streaming I don't really need that I7 horse power and €200 extera that isn't worth it. Keyboard is an doubt but I will be looking more for an other keyboard.
Hay guys, Thanks for all your feedback about my setup, first of all I will never pirate windows because it is really just disrespectful for micresoft and for the poeple who have sat for hours working on it.
The things I have upgraded from all your feedback
GPU: was a evga gtx 960 2gb ftw, decided for a Evga gtx 970 ftw+
I found a better price for my case.. just 13 cheaper but worth it..
and a much better price for a reasonable HDD thats over 40 cheaper
<3 to all of you
1 hour ago, Acrobit said:
Hello, strealth80
Direct X 12 will perform better on more cores, that's why I recommended it. The build fits within your 1400 euro budget and would be what I would buy.
I would also ask you to consider the AMD 390 over the 970 as it is a slightly faster card, unless you have a gsync monitor or require CUDA
Ryzen Ram Guide
It's legal, I'm gonna keep using it until it becomes otherwise. Software companies make billions, they still make money from this "exploit"
Ryzen Ram Guide
