I first burned my OS onto a cd then notice that I don't have a CD drive to install on my future custom PC. Then I tried to burn onto a USB which I then tested onto my current pc and it failed to launch the windows installation splash screen when I selected to boot it. I got my ISO and key from a service for students called dream sparks (Click here to see). The image of windows is 8.1 industry pro. I am currently trying to install a copy of windows media creation tool from Microsoft but I don't know which version to use because my key only works with industry pro which is not listed on the creation tool program. I would order a CD drive but it will come later then the parts.
My PC (Big Blue)
Cpu- Amd Fx 6300
Gpu- GTX 960 4gb
Motherboard- Asus M5A97 plus
Ram- Hyper X Fury 8gb 1866
PSU- EVGA 600b
HDD- WB Blue
SSD- MX Crucial 250gb
Case- NZXT s340 Black/Blue
https://linustechtips.com/topic/571322-problem-with-burning-os/
I don't believe Industry Pro is actually supposed to run on a regular desktop. It's en embedded systems os.
My Build:
CPU: i7 4770k GPU: GTX 780 Direct CUII Motherboard: Asus Maximus VI Hero SSD: 840 EVO 250GB HDD: 2xSeagate 2 TB PSU: EVGA Supernova G2 650W
https://linustechtips.com/topic/571322-problem-with-burning-os/#findComment-7491435
https://www.microsoft.com/windowsembedded/en-us/windows-embedded-8-industry.aspx
Industry Pro versions of Windows run on things like Point of Sale devices.
AMD Ryzen 7800 X3D, MSI B650 Project Zero, Antec C5, Gigabyte RTX 4080 Super Aero
Nikon D500 | Nikon 300mm f/4 PF  | Nikon 200-500 f/5.6 | Nikon 50mm f/1.8 | Tamron 70-210 f/4 VCII | Sigma 10-20 f/3.5 | Nikon 17-55 f/2.8 | Tamron 90mm F2.8 SP Di VC USD Macro | Neewer 750II
https://linustechtips.com/topic/571322-problem-with-burning-os/#findComment-7491449
what do you mean?
My PC (Big Blue)
Cpu- Amd Fx 6300
Gpu- GTX 960 4gb
PSU- EVGA 600b
HDD- WB Blue
https://linustechtips.com/topic/571322-problem-with-burning-os/#findComment-7491451
3 minutes ago, Matrix13 said:
what do you mean?
It's not regular Windows 8.1, it's named the same but it's fundamentally different.
My Build:
https://linustechtips.com/topic/571322-problem-with-burning-os/#findComment-7491477
Will the key for it work with regular windows 8.1 pro
My PC (Big Blue)
Cpu- Amd Fx 6300
Gpu- GTX 960 4gb
PSU- EVGA 600b
HDD- WB Blue
https://linustechtips.com/topic/571322-problem-with-burning-os/#findComment-7491482
No.
My Build:
https://linustechtips.com/topic/571322-problem-with-burning-os/#findComment-7491483
Unlikely. Doesn't your Dreamspark account have normal Windows operating systems on offer?
https://linustechtips.com/topic/571322-problem-with-burning-os/#findComment-7491488
No but if I get windows 10 since it is free do I have to activate it
My PC (Big Blue)
Cpu- Amd Fx 6300
Gpu- GTX 960 4gb
PSU- EVGA 600b
HDD- WB Blue
https://linustechtips.com/topic/571322-problem-with-burning-os/#findComment-7491540
Windows 10 needs to be activated with either a valid Windows 7, Windows 8.1 or Windows 10 key.
https://linustechtips.com/topic/571322-problem-with-burning-os/#findComment-7491553
No to both questions. While it is called "windows 8.1", it isn't at the same thing, they are two completely different products. The key will not work for Windows 8.1 pro or to activate Windows 10.
https://linustechtips.com/topic/571322-problem-with-burning-os/#findComment-7491562
