BF4 Beta Ideas Access Help
Solved by MrGidwani,
If you had premium on console, it doesn't give it to you on PC, you need to have Premium on PC. The only other way is if you pre-order the digital deluxe edition or if you happened to pre-order MoH:WF. Getting BF4 Premium doesn't get you into the beta, I see where you're coming from saying that, "I paid another $50 for premium and I still don't get into the exclusive beta" but I just don't think you're gonna get any help from EA. Just to clarify though, you do realize that the beta access you're referring to is to an 'Exclusive Beta'? Having Premium gives you access to the exclusive beta which begins 3 days before the open beta, but after that, you'll be able to play just like everyone else in the world ![]()
