So I recently built my starter gaming rig but I've encountered issues. Some games crash my pc and make it restart. I manage to fix it sometimes by lowering my graphics, even though GeForce experience says I can do better. Please help. Now it's started to make some odd noises and I don't know what else to do
Evga gtx 750 ti, apevia java 500 watt psu, amd fx 6300 black edition, hyper x fury 8gb ram
https://linustechtips.com/topic/570900-pc-help/
What's making weird noise?
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
https://linustechtips.com/topic/570900-pc-help/#findComment-7487440
I'm usually one to try and truly diagnose the problem before going after a lackluster piece of hardware. I'll still try and help determine any problems, but that PSU has bad news written all over it.
- ASUS X99 Deluxe - i7 5820k - Nvidia GTX 1080ti SLi - 4x4GB EVGA SSC 2800mhz DDR4 - Samsung SM951 500 - 2x Samsung 850 EVO 512 -
- EK Supremacy EVO CPU Block - EK FC 1080 GPU Blocks - EK XRES 100 DDC - EK Coolstream XE 360 - EK Coolstream XE 240 -
https://linustechtips.com/topic/570900-pc-help/#findComment-7487466
Could it be your hard drive or ssd?
Try takng out your memory, CPU and GPU and reseating them.
Intel Core i5-4460 3.2GHz Turbo 3.5GHz | 8GB Kingston DDR3-1333 | MSI Radeon R7 370 OC to 1020mhz | EVGA Supernova NEX B1 750W | GIGABYTE GA-B85-D3H | Inwin Velocity OEM Case | 120mm broken fan
Vancouver, BC | O Canada
https://linustechtips.com/topic/570900-pc-help/#findComment-7487492
Download a program called ClockBlocker and see if it fixes it (It stops your gpu from being downclocked in games when not in full use)
  • CPU: AMD athlon  860k
  • Motherboard: Gigabyte F2A58M-HD2
  • RAM:2x4gb HyperX Fury
  • GPU: XFX R9 380 4gb
  • Case: NXZT S340
  • PSU: EVGA 650G
  • Display: BenQ GL2460HM
  • Cooling: Hyper 212 Evo
  • Keyboard: Corsair k60
  • Mouse: Steelseries Rival 300 (white
  • Sound Logitech g430
  • Operating System: Windows 10 64bit
https://linustechtips.com/topic/570900-pc-help/#findComment-7487538
