Motherboard: Asus Maximus VII Ranger
CPU: Intel i7-4790k (Not going to be overclocked)
GPU: Asus AMD Radeon R9 290X Matrix Platinum GDDR5
RAM: Corsair Vengence Pro Series 16GB DDR3 2133Mhz
HDD: WD Black 3.5inch 1TB SATA Hard Drive
SSD: Crucial BX100 250GB
CPU Cooler: Cooler master hyper 212 Evo
Case: NZXT Phantom 630
OS: Windows 7 or 10
Also, I need a PSU, what wattage should it be and could you recommend one if you can please.
Thank you.
https://linustechtips.com/topic/570812-help-would-this-work/
OS: Windows 7 or 10
Thank you.
What is your budget?
  • CPU: AMD athlon  860k
  • Motherboard: Gigabyte F2A58M-HD2
  • RAM:2x4gb HyperX Fury
  • GPU: XFX R9 380 4gb
  • Case: NXZT S340
  • PSU: EVGA 650G
  • Display: BenQ GL2460HM
  • Cooling: Hyper 212 Evo
  • Keyboard: Corsair k60
  • Mouse: Steelseries Rival 300 (white
  • Sound Logitech g430
  • Operating System: Windows 10 64bit
https://linustechtips.com/topic/570812-help-would-this-work/#findComment-7486612
OS: Windows 7 or 10
Thank you.
That SSD is kind of scary. Get a Samsung 850 EVO or a Kingston Savage
https://linustechtips.com/topic/570812-help-would-this-work/#findComment-7486630
