Well I've recently been experiencing fan vibration on my build which is like 2 months old. I want to know if there is a way to figure out what specific fan is causing the vibrations. It's really annoying since the whole desk vibrates with it, so I guess, but there is like, 3 case fans, 3 GPU fans, 1 CPU fan as well as 1 PSU fan.And by the way, should I leave my build on top of my desk or down on the floor?
So yeah, thanks!
https://linustechtips.com/topic/570778-fan-question/
So yeah, thanks!
It's almost definately not ur fans.  Go into ur pc and check that no wires are in the way of the fan blades.  If there are no wires, I'm pretty sure its ur hdd.
I can help with programming and hardware.
<Script>alert("This website is vulnerable to XSS");</Script>
https://linustechtips.com/topic/570778-fan-question/#findComment-7486353
Put your ear up to each fan and you should be able to tell if one specific fan is causing the problem.
Pro Tip: don't use flash when taking pictures of your build; use a longer exposure instead. Prop up your camera with something (preferably a tripod) if necessary.
if you use retarded/autistic/etc to mean stupid please gtfo
https://linustechtips.com/topic/570778-fan-question/#findComment-7486371
It might be an HDD. I had an older one that literally shook the desk whenever disk usage was high.
GAMING PC "Ol' Bessie":
Ryzen 7 7800X3D | Radeon RX 9070 XT | Gigabyte B650M AORUS Elite AX | G.Skill Flare X5 6000MT/s CL36 16GBx2 | 5TB of SSD POWER | EVGA SuperNOVA 850W GT | Noctua NH-U14S | Fractal Design Pop! Mini AirCachyOS
Kind Of A Home Lab "Bay":
Ryzen 9 5900XT | Intel ARC A310 | ASUS PRIME B550-PLUS | T-FORCE 3200MT/s 16GBx2 + Corsair 3200MT/s 32GBx2 = 96GB!!! WOW!! | 2TB boot SSD + 8TBx6 HDD RaidZ2 | EVGA SuperNOVA 650W G2 | Phanteks Enthoo Pro M | Ubuntu 24.04 LTS
The Laptop:
Framework Laptop 13 | Intel i5-1340p | G.Skill Ripjaws 3200MT/s 16GBx2 | Solidigm P44 Pro 2TB | CachyOS
https://linustechtips.com/topic/570778-fan-question/#findComment-7486389
Make sure all your components are mounted properly and tightly.
I suggest getting some anti vibration mounts because they're just really cheap rubber pieces that go a long way.
My guess is after 2 months of vibrations, something has worked it's way loose to compound the issue.
Check all your screws before anything else.
https://linustechtips.com/topic/570778-fan-question/#findComment-7486398
You were right, one of my two HDD is the cause of that vibration. Now, both my HDD are almost brand new, so either it's not screwed in correctly or otherwise what can I do?
https://linustechtips.com/topic/570778-fan-question/#findComment-7486428
If your HDD is attached directly to the case, metal to metal, then put some kind of rubber/soft pad in between it and the case. That fixed it for me. HDD's naturally vibrate, since they're spinning at 5400RPM or higher, so you need to put something to dampen that vibration.
The Laptop:
https://linustechtips.com/topic/570778-fan-question/#findComment-7486434
8 minutes ago, Kobathor said:
It's on a bracketIf your HDD is attached directly to the case, metal to metal, then put some kind of rubber/soft pad in between it and the case. That fixed it for me. HDD's naturally vibrate, since they're spinning at 5400RPM or higher, so you need to put something to dampen that vibration.
It's on a bracket for a 3.5 inch drive, whats strange is I've got both HDD in RAID 1 but only the bottom HDD vibrates.
https://linustechtips.com/topic/570778-fan-question/#findComment-7486477
That is a bit weird. Make sure both the drives are functioning correctly.
The Laptop:
https://linustechtips.com/topic/570778-fan-question/#findComment-7486495
Thanks you buddy, after tinkering around not only did I add another fan to my CPU heatsink, I tried rescrewing the HDD onto the bracket. After powering it up, I said, "well maybe it's just a fucked up bracket!" . And guess what, it was the stupid bracket!
https://linustechtips.com/topic/570778-fan-question/#findComment-7487057
Well that's good news. Yeah, for me it wasn't screwed in all the way.
The Laptop:
https://linustechtips.com/topic/570778-fan-question/#findComment-7487069
Sure is good news, I've also decided to let it sit on the floor rather then on my desk. That way if it happens again I won't notice it.
Just make sure it's not on carpet, since that'll dust up your PC.
The Laptop:
https://linustechtips.com/topic/570778-fan-question/#findComment-7487112
