I have a MPower Max AC motherboard which has 3 PCI express x16 slots
and two of these Graphic cards --EVGA GeForce GTX 980 ti classified acx 2.0+
For some reason I have two different manuals
one of them says to put the second Graphic card in the furthest PCI express x16 slot away from the CPU
But the second one I have says to put the 2nd Graphic card in the second PCI express x16 slot
Which do I do??
https://linustechtips.com/topic/570642-2-way-sli-help/
Which do I do??
manual doesnt say
although, as with all motherboards, it is probably the closer to the top one
https://linustechtips.com/topic/570642-2-way-sli-help/#findComment-7485120
Picture?
I am guessing your pcie config is
From top to bot
Pciex16
Pcie2.0 x4
Pcie2.0 x4
Pciex16
Pcie2.0 x4
Pciex16
My intuition says the top most x16 and the next nearest x16 slot would be what you want to use.  I dont know if your sli bridge will be long enough to connect two cards in the farthest pcie slots anyways.  I am guessing that the bottom most pciex16 slot shares lanes with the m.2 interface, so definitely avoid using that one.
https://linustechtips.com/topic/570642-2-way-sli-help/#findComment-7485121
1 hour ago, xentropa said:
Picture?
From top to bot
Pciex16
Pcie2.0 x4
Pcie2.0 x4
Pciex16
Pcie2.0 x4
Pciex16
https://linustechtips.com/topic/570642-2-way-sli-help/#findComment-7485272
2 hours ago, C13GE said:
From reading on the MSI website, you would put them into the highest two (closest to the CPU) PCIe slots and they will run in x8,x8 mode.
2 hours ago, Josephdalepi said:
manual doesnt say
2 hours ago, xentropa said:
Picture?
From top to bot
Pciex16
Pcie2.0 x4
Pcie2.0 x4
Pciex16
Pcie2.0 x4
Pciex16
Both of these manuals came in the same box my graphic cards came incpu.jpg.d52f29699c35c693a153bb7116f0af2esecond.jpg.0b86fb8c3624a14ddb40226394df5
https://linustechtips.com/topic/570642-2-way-sli-help/#findComment-7485364
