Ive never upgraded or really worked with pc parts and i want to upgrade from my integrated gpu to a dedicated card.
Will a gtx 950 (17cm long) fit in my pc? Please look at everything carefully because it seems as if some other things are blocking it but i have no clue.
*the mobo say "minipciex1" so if thats important it is a 17cm gpu*
Thanks!
Edited by BenKavanagh
More info
https://linustechtips.com/topic/570603-need-help-asap/
Yeah it will fit. Just shift your wifi antennas down one slot or something. The expansion slot covers can be removed.
Frost | 7700K @ 4.9GHz 1.36v, delidded | Asus DUAL GTX 1060 6GB OC | Corsair LPX 16GB DDR4 2800MHz | Samsung 960 EVO 250GB SSD + Toshiba 1TB HDD + Toshiba 2TB HDD + Samsung 860 EVO 1TB SSD for macOS | Asus PRIME Z270-A | Fractal Design Celsius S24 | Seasonic M12-II 620W PSU | Corsair 400C White | NZXT Hue+
Samsung Galaxy S8 | Stock
Ticwatch E (Black) | Ticwatch Brown Leather Strap
https://linustechtips.com/topic/570603-need-help-asap/#findComment-7484796
Thanks!
whats your case model?? thats what we need to know
https://linustechtips.com/topic/570603-need-help-asap/#findComment-7484799
34 minutes ago, BenKavanagh said:
The problem is its a stock prebuilt desktop so no really defined case
You can give the make/model of the computer though.
Screenaninator: Sapphire Radeon R9 390 Nitro
Procrastinator: AMD FX-8300
Stickaminator: 16GB Crucial Vengance DDR3
Powermathingy: Corsair RM850i
attachamajiggy: Asus M5A97 R2.0 f
Remembrerthing: 240 GB Crucial SSD, 2TB Toshiba HDD
https://linustechtips.com/topic/570603-need-help-asap/#findComment-7484892
Asus m32
You should be able to fit it just fine. I had the Asus M52BC, and was able to fit my Radeon R9 390 in it. (It was a bit of a snug fit, but it will fit)
https://linustechtips.com/topic/570603-need-help-asap/#findComment-7484916
2 hours ago, goodtofufriday said:
Yeah Ram clips MIGHT be an issue. But you can just trim off some of the plastic on them and be fine.
In mine, it was a snug fit, but it did fit. They use the same case, but I believe it is a different mobo.
https://linustechtips.com/topic/570603-need-help-asap/#findComment-7486691
