Good Material for a Replacement Side Window
Solved by W-L,
4 minutes ago, C13GE said:Hey guys,
I have a Corsair C70 Gun Metal black that I plan on modding. I was wondering what a good material is that won't bend or melt. My computer sits around 25-45 degrees celsius. I've came up with clear acrylic. Let me know your suggestions.
Thanks,
C13GE
MNPC tech makes replacement windows for the C70 if your interested but my personal favorite would be to replace it directly with a glass side panel as it doesn't scratch as easily:
-Moved to Modding Section-
