Air-cooling Noctua
Dog_tech
Does anyone know if I can fit a ppc fan on the U14s or got to stick with the a15.
You can use any fan you like so long as it meets these specs:
140x150x25 (with 120mm mounting holes), 140x140x25 (with 120mm mounting holes), 120x120x25
You can see the full specs and tech diagrams here:
http://noctua.at/en/products/cpu-cooler-retail/nh-u14s/specification
浪速の建てるは静か用に建てました!- Build Log Coming Soon!
1 minute ago, Dog_tech said:
Thanks so it will work right?
You would be stuck with a 120mm fan but it should work.
OK so 120mm will work thanks. But 140mm can that work?
As long as the 140mm fan has 120mm mounting holes then yeah. So its either 120mm, or what comes with the cooler.
Yes but only if the 140mm fan has 120mm mounting holes!
7 minutes ago, Dog_tech said:
No. It would need 120mm mounting holes iirc.
Star Citizen referral codes, to help support your fellow comrades!
UOLTT Discord server, come on over and chat!
i7 4790k/ Bequiet Pure Rock/Asrock h97 PRO4/ 8 GB Crucial TT/ Corsair RM 750/ H-440 Custom/  PNY GT 610
Damn you're like a modular human being. -ThatCoolBlueKidd
thanks for the answers and what do you guys think on my choice on the cooler is this a good buy
