HELP NOOOOW
Go to solution Solved by Levent,
windows cannot read ext3 without extra 3rd party software
ok so i have a qnap ts 219p
and i took one of the HDD's out and put it in my pc to try and read it
explorer dont find it but in disk manager it does however it dont display a file system
and whilst i do this i reset my nas drive so the other one gets wiped can someone tell me why the F my computer cant read the HDD
i know the hdd has a file format windows can read cuz its ext3
the hdd is a 2tb barracuda
just in case the pic dont load
http://www.mediafire.com/view/s4sefcd5ef1powe/Untitled.png
updated image
https://linustechtips.com/topic/56955-help-noooow/
https://linustechtips.com/topic/56955-help-noooow/#findComment-770580
People help when you ask them to, the thread title was not necessary or polite.
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
https://linustechtips.com/topic/56955-help-noooow/#findComment-770600
