Are these temps normal?
Go to solution Solved by desertcomputer,
Yes, looks fine.
Yes, looks fine.
Magical Pineapples
https://linustechtips.com/topic/568514-are-these-temps-normal/#findComment-7463830
yes
https://linustechtips.com/topic/568514-are-these-temps-normal/#findComment-7463836
8 minutes ago, xHadrian said:
Thanks for the feedback, just was concerned. #hype :P
if it goes above 75*C, then there would be cause for concern. Intel CPUs can withstand up to 100*C
https://linustechtips.com/topic/568514-are-these-temps-normal/#findComment-7463861
1 minute ago, xHadrian said:
I was concerned because it was a custom loop.
Water cooling isn't used for much lower temps, it's mainly for silenece and aesthetics - it's not practical
https://linustechtips.com/topic/568514-are-these-temps-normal/#findComment-7463868
30 minutes ago, xHadrian said:
EK Kit X360, 5820k.
Assembled one day ago.
Are these temps normal for a custom loop?
https://gyazo.com/a9840a44cf4925f8e739be3385c2f2ec
OC'ed to 4.5 GHz, idle.
yup you good
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/568514-are-these-temps-normal/#findComment-7463904
