Hello, i am looking to upgrade my pc and had a couple questions, would an i3 6100 paired with a gtx 950 get 150> fps,  with low to med settings? The only reason i ask is i plan to got a 144 hz monitor.  This is my build.   EDIT** I play CS GO and League of Legends
PCPartPicker part list: http://pcpartpicker.com/p/VgTtVn
Price breakdown by merchant: http://pcpartpicker.com/p/VgTtVn/by_merchant/
CPU: Intel Core i3-6100 3.7GHz Dual-Core Processor  ($106.00)
Motherboard: MSI B150M MORTAR Micro ATX LGA1151 Motherboard  ($87.89 @ Amazon)
Memory: G.Skill Ripjaws V Series 8GB (2 x 4GB) DDR4-2400 Memory  ($36.99 @ Newegg)
Storage: PNY CS1311 120GB 2.5" Solid State Drive  ($39.99 @ Amazon)
Video Card: MSI GeForce GTX 950 2GB Video Card  ($142.98 @ Newegg)
Case: Phanteks ECLIPSE P400 ATX Mid Tower Case  ($74.99 @ Amazon)
Power Supply: EVGA SuperNOVA NEX 750W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($54.99 @ Newegg)
Operating System: Microsoft Windows 10 Home Full - USB (32/64-bit)  ($104.99 @ SuperBiiz)
Monitor: Acer GN246HL 144Hz 24.0" Monitor  ($150.00)
Total: $798.82
Generated by PCPartPicker 2016-03-19 22:50 EDT-0400
Thanks for the help!
Edited by Crazycat233
https://linustechtips.com/topic/568380-need-help-with-build/
Total: $798.82
What games do you play? The amount of fps is determined by how demanding your games are.
My native language is C++
https://linustechtips.com/topic/568380-need-help-with-build/#findComment-7462446
I'd go for this instead:
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($196.99 @ SuperBiiz)
Motherboard: Gigabyte GA-H110M-A Micro ATX LGA1151 Motherboard  ($51.89 @ OutletPC)
Storage: A-Data Premier SP550 120GB 2.5" Solid State Drive  ($38.99 @ Amazon)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.49 @ OutletPC)
Video Card: Sapphire Radeon R9 380 4GB NITRO Dual-X OC Video Card  ($188.98 @ Newegg)
Case: Thermaltake VL80001W2Z ATX Mid Tower Case  ($24.99 @ Micro Center)
Operating System: Microsoft Windows 10 Home Full - USB (32/64-bit)  ($20.00)
Total: $813.31
Generated by PCPartPicker 2016-03-19 23:05 EDT-0400
Everyday build:
CPU: Intel Core i7 5960x - GPU(s): 2x EVGA GTX 980 Ti Superclocked+ ACX2.0+ (SLI) - Cooler: be quiet! Dark Rock Pro 3 - Motherboard: ASUS Sabertooth X99 - RAM: 32GB Kingston HyperX Fury Black DDR4 4x8GB (2666MHz) - Storage: Intel 750 Series 1.2TB + 4TB WD Black - Case: Corsair 760T White - PSU: SeaSonic 1200W 80+ Platinum Certified - OS: Windows 10 Pro - Wireless Adapter: TP-Link Archer T9E - Monitor: Acer XB270HU bprz - Keyboard: Corsair K70 RGB - Mouse(s): Corsair Gaming M65 RGB + Logitech MX Master - Headphones: Sennheiser PC363D
http://pcpartpicker.com/p/WhyK99 https://linustechtips.com/main/topic/474247-r8-my-build/
Weekend build:
CPU: Intel Core i7 5930k - GPU(s): 2x EVGA GTX 980 Ti Classified ACX2.0+ (SLI) - Cooler: NZXT Kraken X61 - Motherboard: ASUS X99-Deluxe - RAM: 32GB Crucial Ballistix Sport LT DDR4 4x8GB (2666MHz) - Storage: Samsung 950 Pro 512GB m.2 & 2TB Samsung 850 Evo - Case: Phanteks Enthoo Evolv - PSU: SeaSonic SnowSilent 1050W 80+ Platinum Certified - OS: Windows 10 Home - Monitor: Dell S2716DG 144hz - Keyboard: Corsair STRAFE RGB - Mouse: Corsair Gaming M65 RGB - Headphones: Sennheiser PC363D
http://pcpartpicker.com/p/YYK93C
https://linustechtips.com/topic/568380-need-help-with-build/#findComment-7462515
Total: $813.31
How do I get OS for twenty dollars?
https://linustechtips.com/topic/568380-need-help-with-build/#findComment-7462875
Reddit ($20) or G2A
Everyday build:
Weekend build:
https://linustechtips.com/topic/568380-need-help-with-build/#findComment-7464122
14 minutes ago, Crazycat233 said:
Isn't that not safe?
It's safe
Everyday build:
Weekend build:
https://linustechtips.com/topic/568380-need-help-with-build/#findComment-7464244
So getting an OEM is ok?
Should be
Everyday build:
Weekend build:
https://linustechtips.com/topic/568380-need-help-with-build/#findComment-7464256
