so, i recently had to re install windows 10. as the nvidia driver fail, messed up something on my pc and yeah that was what ended up having to happen lol regardless, here is a screenshot i have now.
My question is this, the Temp #4. *technically, each of them Temp # 1,2,3,4* what is that reading for exactly? and why is #5 so low vs the others. I have seen that #4 stays kinda higher then the others. in this screenshot it shows 34c vs mid to upper 20's for the others accept #5. but what made me wonder about this in the first place was because #4 was around 40 low 40's and the others *again besides #5* were hanging around low 30's
https://linustechtips.com/topic/568223-temps/
these are the sensors of your mobo, maybe take a look at your manual and try to find out more where the sensors are placed.
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
https://linustechtips.com/topic/568223-temps/#findComment-7460789
Those are temps for different things on the MB. The #4 i probably for VRM, so that's why it's higher than others, for example chipset temp.
CPU: i7 3770K | MB: EVGA Z77 FTW | RAM: HyperX Savage 2400Mhz 16GB | GPU: R9 280X Toxic | Cooler: Scythe Fuma | PSU: CoolerMaster B600
SSD: Crucial MX300 525GB | HDD: Seagate Barracuda 7200.12 500GB - Toshiba DT01ACA300 3TB
https://linustechtips.com/topic/568223-temps/#findComment-7460807
18 hours ago, MichiganChucker said:
ah ok, thanks to the both of u. Im looking now in the manual to find any info on the sensors, acceptable ranges of temps.
acceptable temps for mobos are in my opinion the same as for the cpu/gpu: best are in the 60-70°C range (full load), <90°C not for longer use and at idle in the max 30°C range.
- Ryzen Build -
2x Dell UP2516D
https://linustechtips.com/topic/568223-temps/#findComment-7464623
