Mini ITX build
Go to solution Solved by Samfisher,
Yes, no, yes.
I've pretty much finalised this build and thought I'd see if you guys agree, couple questions I'd like answering:
1. will 550w be enough? (I'm 99% sure it will be)
2. could the GPU choke due to the PSU being close to it?
3. will 1 intake and 1 exhaust suffice? thanks.
Spec:
Fractal Design Nano S
Asus Z170i Pro Gaming motherboard
Corsair Vengeance LPX DDR4 2400 2x4gb
i5 6500
Sapphire R9 380X Nitro Dual-X GPU
Samsung 850 Evo 250gb SSD
WD 1tb Blue HDD
EVGA Supernova 550w GS
https://linustechtips.com/topic/567573-mini-itx-build/
i believe th if you add another fan on the top of thecase, and something to push the hot ari away of the psu's way to the cpu...
Project "Transcend": i7 7700k-R9 380 4GB by MSi, Z170-HD3P
My Steam Profile (from SteamDB)
  • Worth: $453 ($123 with sales)
  • Games owned: 76
  • Games not played: 40 (53%)
  • Hours on record: 667.0h
https://linustechtips.com/topic/567573-mini-itx-build/#findComment-7454673
1. yes, with a good psu (yours is fine)
2. depends, but most probably no
3. if your 1 exhaust is including the psu then sure, if you have 1 fan as intake and 1 fan as exhaust but also have psu as exhaust, then you might wanna get more intake
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/567573-mini-itx-build/#findComment-7454687
Problem with that case though, removing the top moduvent makes it look hideous :(
double fan on the exhaust, so that the air will flow faster? Extremely ghetto, i know, but, ghetto ore running faster and cooler? ask around, im not that experienced tho....
  • Games owned: 76
https://linustechtips.com/topic/567573-mini-itx-build/#findComment-7454690
Yeah that does sound ghetto haha, I'm sure it will be fine like.
https://linustechtips.com/topic/567573-mini-itx-build/#findComment-7454693
Its better to have a nasty machine than a sexy furnace. everyone likes a good looking build but Never compromise performance and rig life for looks.
                   _/ V\
    ______|   __/_/| |
   /_______\______}\__}
[I5-12600k | 32gb DDR5 6000 | RTX5070 | 2x1tb M.2]
[Ryzen 5 1600 | 16gb DDR4 3200 | GTX1030 | 4x 8tb HDD]
https://linustechtips.com/topic/567573-mini-itx-build/#findComment-7454712
To be fair though, 2X140mm intake fans and 1x120mm exhaust should be enough for a non-OC'd i5 6500 and a non-OC'd R9 380X surely?
https://linustechtips.com/topic/567573-mini-itx-build/#findComment-7454725
With non OC and if the case itself has good venting it should be, but still, if it starts running red don't abuse it lol
                   _/ V\
    ______|   __/_/| |
https://linustechtips.com/topic/567573-mini-itx-build/#findComment-7454737
Haha yeah, another question for you and anyone that could help, I plan on getting the Cooler Master GeminII S524 V2 for it, will I run into any problems with that motherboard?
https://linustechtips.com/topic/567573-mini-itx-build/#findComment-7454761
Yeah... on 2nd thought, i agree with the best answer guy
  • Games owned: 76
https://linustechtips.com/topic/567573-mini-itx-build/#findComment-7466544
