that should work as far as i know
Builds:
1 minute ago, Bread Doctor said:
Hey guys,
This is my first build and I have selected all the parts I want, According to pcpartpicker everything is compatible but just wanted to check with others that this is the case!
Thanks :D
http://uk.pcpartpicker.com/p/TrwgD3
no, not compatible at all!
THE COLOURS ARE ALL WRONG! D<
on a serious note, yea they will work, not sure about the cooler with ram clearance though
suggestion:
a 2tb hard disk offers better value than 1tb, maybe get that if you dont mind the slight increase in cost
a 390 will be better in games and at higher resolution than the 970, so you can consider that if you dont need nvidia's features
-sigh- feeling like I'm being too negative lately
10 minutes ago, Bread Doctor said:
Hey guys,
Thanks :D
The R9 390 is better(has more VRAM) than the 970 and is also cheaper. Otherwise, very solid build.
CPU:Intel Core i3 3210 Mobo:MSI B75MA-E33  GPU:Intel 2500 HD Graphics  SSD:Adata SP600 128gb  HDD:Seagate 1tb 7200rpm
PSU:Corsair CX430   Case:Antec ASK4000bU3  Monitor:Dell S2240l 21.5 inch 1080p
Thanks for the tips, lol apart from the mobo which i can only get in orange I kinda like the white/black/red look :P Ill look into clearance with the cooler a bit but not entirely sure about the 390 yet as Nvidia seems better optimised with some of the games im interested in e.g. the witcher and rise of the tomb raider.
