On 3/17/2016 at 7:10 PM, done12many2 said:
Do you not like the fan controller built into your motherboard?
yes it sucks and only supports 2 fans. that have pwm rest is dc ughh
CPU: Intel Core i9 9900K | Ram: 32GB Corsair LPX 3200 DDR4 | Asus Maximus XI Hero Z390 | GPU: EVGA RTX2080 XC | 960 EVO Samsung 500GB M.2 | 850 EVO Samsung 250GB M.2 | Samsung 1TB QVO SSD | 1TB HDD WD Blue
https://linustechtips.com/topic/566717-fan-controler/#findComment-7457506
Just now, done12many2 said:
How many fans are you planning on running?  Check the max amp/wattage rating for your motherboard's PWM headers.  You might be surprised how many fans you can safely run off of one PWM header let alone two.
5 2 for watercool and 3 for case.
https://linustechtips.com/topic/566717-fan-controler/#findComment-7457556
Double check your fan's amperage and wattage draw.  Also make sure they are 4 pin PWM fans.   If they are 3 pin fans you'll need to see if your board supports DC mode and if so the motherboard's fan controller can control them.
Look up the safe output for your PWM headers and make sure that the combined total of all fans to be run on that single header don't exceed the headers capacity.
You'll need some PWM or 3 pin fan splitters.
I run 13 PWM fans and a water pump (control only) off of my motherboard not because I didn't want to buy a fan controller, but because  my motherboard's fan controller was a lot better than anything else I wanted to use.
https://linustechtips.com/topic/566717-fan-controler/#findComment-7457602
