Hello, I bought a prebuilt computer a little while ago and it is running great on csgo but i want to play more intensive games.
Here is the link to my computer: Best Buy
Quick specs are:
CPU: AMD FX 4300 @3.8Ghz
RAM: 8G(Brand i do not know)
OP: Windows 10
Hard Drive: 1Tb @ 7200 rpm
Power supply: 300
Motherboard: MSI 760GM-P23(FX) (MS-7641) 3.0
But here is the Graphics card i have: AMD Radeon R7 240
The question i have here is what is a good graphics card i should get and do i need to upgrade my power supply.
Thank You,
Chance B.
https://linustechtips.com/topic/566671-need-help-with-my-pre-built-pc/
Just now, Chance said:
@ELSknutsonThank you for the input. When I bought it i dint know that was a bad graphics card until i saw linus video on it.
the system is pretty limited as far as expanding it goes  before you buy any grapics card make sure you power supply has the connectors for it otherwise you will need to get a GPU that does not require a power connector and runs off the PCIE slot,  If you try to upgrade that prebuilt system's PSU you may run into compatibility issues. Please keep us  informed about what you plan on doing so you dont end up spending extra on parts you can not use.
I will make sure i keep you guys informed and that is why im the forum is to make sure i don't do anything the would be un-compatible.
4 minutes ago, ELSknutson said:
something like this should work for you http://www.newegg.com/Product/Product.aspx?Item=N82E16814487024
That grpahics card looks great and in my price range. i couldnt open my power supply area to see the connectors unless im looking for the wrong thing but here is the picture of the sticker of the PSU.
  • 1 month later...
On 3/16/2016 at 6:15 PM, ELSknutson said:
ya I defiantly wouldn't get anything over a 750ti
UPDATE: So i just ordered the GTX 750 Ti sc. It should arrive at the latest May 5. I willl make another update post as soon as it arrives and i put it in.
