How do i get 144hz monitor working at 144hz??
vaibhav7garg
I just bought a new 144hz display AOC g2460pqu
my pc config is
CPU - AMD A10 7850k
GPU - AMD R7(igpu)
MoBo - Asus A88XM-A
Ram - 8gb(2400hz)
i am using a dual link dvi-d cable.
when i switch the settings to 144hz the monitor goes black for 15seconds and switch back to 60hz..
please help :(
does my onboard gpu and motherboard able to project 144hz?
my pc config is
CPU - AMD A10 7850k
GPU - AMD R7(igpu)
MoBo - Asus A88XM-A
Ram - 8gb(2400hz)
please help :(
Drivers.
Please spend as much time writing your question, as you want me to spend responding to it.  Take some time, and explain your issue, please!
If you need to learn how to install Windows, check here:  http://linustechtips.com/main/topic/324871-guide-how-to-install-windows-the-right-way/
Event Viewer 101: https://youtu.be/GiF9N3fJbnE
4 minutes ago, JefferyD90 said:
Drivers.
thanku for the fast reply.
I have installed amd radeon crimson 15.12 drivers
Never knew AMD R7 is an onboard GPU. AFAIK, it is lower end discrete GPU
Most likely you are mistaken to think that is R7 is an onboard GPU and your intel onboard GPU is incapable to get 144Hz at 1080p.
not onboard gpu..
i have an amd apu processor which has r7 integrated.
Install ALL of your drivers.
yeah i did
just tell me this does my integrated graphics card (r7) would able to run 144hz monitor on a88xm-a motherboard??
or i need to buy a discreet GPU
5 hours ago, vaibhav7garg said:
yeah i did
It should work fine. Can you get it at 120Hz at least?
no only 60hz seems to be working
18 hours ago, vaibhav7garg said:
yeah i did
It does support 144htz (but over Dual-Link DVI and Display Port; Not Single-Link DVI and VGA)
i think i bought a fake dvi-d dual link cable..
i will change the cable and report back
thanks for the help
thanks for the help
ensure the board and monitor are dual link ports
