Please can someone help
Go to solution Solved by Enderman,
1 minute ago, WeeMan85 said:
im going to assume that my MBR is on Disk 0 ??
im not sure what is on what but clearly there is important stuff on both...
clean install windows to fix it
So the other day i decided to pull out my 500 gb HDD and 1tb HDD and put 2x 2gb  hdd's in my pc...
{ Ps Windows is on my SSD }
So when i removed my storage drive (500gb) it was hit with an error like Unable to find Boot: GRUB Recovery...  (sorry cant remember the name and don't want to replicate :P ), and got worried and put it back in and after a but of mucking about in my bios got it working again.
so to cut a long story short i want to take it out and don't know if i can here is a picture of my Disk management
Untitled.png.6b14dea585dfe1f0a4910bb60da
https://linustechtips.com/topic/566043-please-can-someone-help/
why do you have system on one drive and boot on your SSD...
how did you install windows?
did you unplug all drives except the SSD when installing?
https://linustechtips.com/topic/566043-please-can-someone-help/#findComment-7437681
2 minutes ago, WeeMan85 said:
im not sure i just selected my SSD when installing windows and No i left them all in
fyi, theres a quote button for a reason...
and yeah your screwed up your windows install
now you cant boot without both your ssd and your hdd
the only way to fix this is to clean install windows, and this time only have the ssd plugged in while installing
https://linustechtips.com/topic/566043-please-can-someone-help/#findComment-7437720
https://linustechtips.com/topic/566043-please-can-someone-help/#findComment-7437726
https://linustechtips.com/topic/566043-please-can-someone-help/#findComment-7437739
3 minutes ago, WeeMan85 said:
thanks for the help <3
yw :)
https://linustechtips.com/topic/566043-please-can-someone-help/#findComment-7437765
