For a couple of days I have been working on a text to NATO alphabet translator (the Alpha, Bravo, Charlie stuff) and after a little I wanted to add morse code too, so that is implemented now too and now I want to be able to play the morse code too.
Either way, everything works, except for the playing of the morse code. The first character plays and after that it stops, even though it should play (the code does reach all the next sounds), so uhh, I will just show what I am working with:
//MorseSound.js for index.php
//The sound clips
var Short = new Audio('short.mp3');
var Long = new Audio('long.mp3');
//Many function not relevant now
//The functions above take the string of morse code (dots and dashes) and goes over them one by one and see if it is a dash or dot and after that goes to the PlaySound() function so it will play.
//This function work, the trouble begins later
function TranslateToSound()
	for (var e = 0; e < MorseArray.length + 1; e++)
		//I do see all these console logs in the console, screenshot provided below
		if (MorseArray[e] == ".")
			PlaySound(Short);
			console.log("Short");
		if (MorseArray[e] == "-")
			PlaySound(Long);
			console.log("Long");
function PlaySound(Type)
  	//This code only plays one sound and after that goes quiet, even though it still gets accesed.
  	//I have determined the problem must lie here (or in the entire HTML5 audio thing, as it is not meant for this type of stuff..
	Type.play();
As you can see the morse code is three dots (short), three dashes (long), three dots (short) and it gets logged, but only one time the sound gets played (whichever is the first one)
If I do a console.log(Type) in the last function, I will see all mp3 clips get accessed properly too.
If I put an interval of two seconds in TranslateToSound() function it still doesn't work.
Anybody got any ideas?
https://linustechtips.com/topic/566022-javascripthtml5-audio-help/
//The sound clips
			PlaySound(Short);
			PlaySound(Long);
	Type.play();
How long exactly are the MP3s?
Different PCPartPickers for different countries:
UK-----Italy----Canada-----Spain-----Germany-----Austrailia-----New Zealand-----'Murica-----France-----India
10 minutes ago, Stardar1 said:
Well, with an i7, GTX 1080, Full tower and flashy lights, it can obviously only be for one thing:
Solitaire.
They are both 1 second long and the short one is 11,2KB and the long one is 12,4KB
I have not used Javascript before, but I have used Java and other languages.
describe "Type.play()" for me
Solitaire.
Or try this, do Type.play (or start), wait 1 second, then somehow STOP it
Solitaire.
I tried pausing the sound (the .pause() function) but it didn't fix anything.
Meh, I'll check it out tomorrow with a fresh mind again and see if I can think of something else
can you use .start() and .stop()?
Solitaire.
There is no stop function sadly
http://www.w3schools.com/tags/ref_av_dom.asp
Try doing a load before a play.
Solitaire.
	Type.load();
	Type.play();
I did this and it didn't change anything :(
	Type.load();
	Type.play();
load, play, pause?
Solitaire.
4 minutes ago, Stardar1 said:
load, play, pause?
I tried this:
	Type.load();
	Type.play();
	TypeNow = Type;
	setTimeout(StopSound,3000);
function StopSound
	TypeNow.pause();
But now no sound is playing
(Javascript doesn't have a simple sleep function, so it has to be done like this. That number is in milliseconds and I tried 1000 (1 second), but also a couple of other numbers just to see what works
I tried this:
	Type.load();
	Type.play();
	TypeNow = Type;
function StopSound
	TypeNow.pause();
sleep functions are more needed now, and rarer and rarer.
there's no unload...
I have no idea...
Solitaire.
