1. I have a budget of $1000 And i live in Australia
2. My aim is 3d modelling and gaming on games such as arma 3 csgo garrys mod
3. i plan on maybe running 2 monitors
4. the only peripherals i need is a mouse and keyboard
5. i'm upgrading due to living with a dualcore and a geforce 315
What i'm looking at currently
PCPartPicker part list: http://au.pcpartpicker.com/p/FqYr23
Price breakdown by merchant: http://au.pcpartpicker.com/p/FqYr23/by_merchant/
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($275.00 @ IJK)
Motherboard: MSI H81M-P33 Micro ATX LGA1150 Motherboard  ($69.30 @ Newegg Australia)
Memory: Avexir Core Series 8GB (1 x 8GB) DDR3-1600 Memory  ($46.20 @ Newegg Australia)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($69.00 @ Centre Com)
Video Card: PowerColor Radeon R9 380 4GB PCS+ Video Card
Case: Deepcool TESSERACT BF ATX Mid Tower Case  ($49.99 @ Mwave Australia)
Power Supply: EVGA 600B 600W 80+ Bronze Certified ATX Power Supply  ($87.12 @ Newegg Australia)
Keyboard: Cooler Master CM Storm Devastator Gaming Bundle Wired Gaming Keyboard w/Optical Mouse  ($48.00 @ PLE Computers)
Other: Blue Microphones Snowball iCE ($80.50)
Total: $725.11
Generated by PCPartPicker 2016-03-15 22:11 AEDT+1100
The Only problem i've found is that the motherboard doesn't have 3.0ports and it says it'll need a bios update also looking for a better psu
Edited by Marksman
BEHIND YOU
https://linustechtips.com/topic/565819-build-help/
Total: $725.11
get a 390, a h97 mobo and you will be of to the races (btw that psu is fine)
My rig: r7 1700 @ 3.9/1.35v, 16gb ddr4 3200, assorted rando SSDs, hx 1050, vega 64 1650/1025
MY $75 BUILD https://linustechtips.com/main/topic/576889-the-75-build-log/#comment-7547280
https://linustechtips.com/topic/565819-build-help/#findComment-7435332
Total: $725.11
Do you plan on playing anything more intense than Arma 3 and gmod? If so, what is the most intensive game you plan to play? At what settings, res. and frame-rate?
https://linustechtips.com/topic/565819-build-help/#findComment-7435363
Motherboard: MSI H81M-E34 Micro ATX LGA1150 Motherboard  ($78.10 @ Newegg Australia)
Storage: Western Digital WD Blue 750GB 2.5" 5400RPM Internal Hard Drive  ($69.00 @ PCCaseGear)
Video Card: Asus Radeon R9 380 4GB Video Card  ($325.00 @ IJK)
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply  ($79.00 @ PCCaseGear)
Total: $1050.79
Generated by PCPartPicker 2016-03-15 22:33 AEDT+1100
https://linustechtips.com/topic/565819-build-help/#findComment-7435370
So something like this?
PCPartPicker part list: http://au.pcpartpicker.com/p/4TXysY
Price breakdown by merchant: http://au.pcpartpicker.com/p/4TXysY/by_merchant/
CPU: Intel Core i5-6400 2.7GHz Quad-Core Processor  ($270.00 @ CPL Online)
Motherboard: ASRock H110M-DGS Micro ATX LGA1151 Motherboard  ($86.00 @ IJK)
Memory: G.Skill NT Series 8GB (1 x 8GB) DDR4-2133 Memory  ($51.00 @ IJK)
Video Card: EVGA GeForce GTX 950 2GB SSC ACX 2.0 Video Card  ($220.66 @ Newegg Australia)
Power Supply: SeaSonic 550W 80+ Gold Certified ATX Power Supply  ($99.00 @ Umart)
Keyboard: Cooler Master CM Storm Devastator Gaming Bundle Wired Gaming Keyboard w/Optical Mouse  ($44.00 @ Umart)
Other: World of Warships Large Mousepad ($38.36)
Total: $1008.51
Generated by PCPartPicker 2016-03-16 18:07 AEDT+1100
https://linustechtips.com/topic/565819-build-help/#findComment-7440546
20 hours ago, Marksman said:
You can easily go skylake, this board comes with USB 3.1
if you can find this board it's about the best budget 1151 board
https://au.pcpartpicker.com/part/gigabyte-motherboard-gah110ms2hp
also are you sure you need a snowball? look for the snowflake or samson GO mic
PCPartPicker part list: http://au.pcpartpicker.com/p/t76Q8d
Price breakdown by merchant: http://au.pcpartpicker.com/p/t76Q8d/by_merchant/
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($294.00 @ IJK)
Motherboard: MSI H110M Pro-VD Micro ATX LGA1151 Motherboard  ($99.00 @ CPL Online)
Memory: G.Skill NT Series 8GB (1 x 8GB) DDR4-2400 Memory  ($51.98 @ Mwave Australia)
Case: Fractal Design Core 1000 USB 3.0 MicroATX Mid Tower Case  ($69.00 @ IJK)
Total: $1006.98
Generated by PCPartPicker 2016-03-16 18:11 AEDT+1100
https://linustechtips.com/topic/565819-build-help/#findComment-7440559
