VMWare USB Wifi not working with linux
Solved by cloneman,
I'm guessing what you want to do is a USB-Passthrough. This means that Windows does not see the card at all (it sees it as a VMware USB Device), so there's no need to configure it in NAT, or Bridged, or whatever - both VMware and Windows are unaware of the existence of the network card in this mode, and this is what you want.
You simply click the little icons at the bottom of VMware to assign direct access to a USB device in the VM. Then you need to configure it in Kali but it probably already has the drivers.
You can do the same thing with other USB devices, for example, a game controller or camera.
