Reinstall windows .. :)
Magical Pineapples
https://linustechtips.com/topic/565527-hackintosh-problem/#findComment-7432114
Is it looking for that partition first within your bios?  Make sure it's looking for the Windows 10 partition.  It could still be trying to boot from the deleted partition even if you deleted it.
Case: NZXT H500i. Motherboard: Asus Prime Z390-A. CPU: i7 9700k OC @ 5.0GHz. GPU: EVGA 2080 FTW3 CPU Cooler: NZXT X62. Memory: G. Skill Ripjaws 32Gb 3200mhz. Storage: 1TB Samsung 840 EVO SSD /  120GB Samsung 840 EVO SSD  /  WD Caviar Black 3TB / WD Caviar Green 4TB. . PSU: Corsair AX760. Monitor: 2x Acer XB270HU. Keyboard: Corsair K70 RGB. Mouse: Corsair Glaive.
https://linustechtips.com/topic/565527-hackintosh-problem/#findComment-7432115
How would I even know?
https://linustechtips.com/topic/565527-hackintosh-problem/#findComment-7432155
Go into your bios and check.  Check your mobo manual.  It will tell you where you access your boot options.
https://linustechtips.com/topic/565527-hackintosh-problem/#findComment-7432205
I checked my bios it doesn't say anything about partitions. So Windows is trying to boot from a deleted partition how would I fix it?
https://linustechtips.com/topic/565527-hackintosh-problem/#findComment-7432373
