no they are not supposed to
there should always be a gap between the two pieces
https://linustechtips.com/topic/565419-compression-fittings/#findComment-7431057
1 hour ago, WCNewb said:
Quick question regarding these fittings, should they screw up fully? I've been fitting together some tubing but some fittings don't tighten as much as others, however the tube is firmly in place and I don't see it leaking at all. Is there something I'm missing here?
If that's as tight as you can get them and the fittings aren't leaking, then you're fine.
Wife's build: Amethyst - Ryzen 9 3900X, 32GB G.Skill Ripjaws V DDR4-3200, ASUS Prime X570-P, EVGA RTX 3080 FTW3 12GB, Corsair Obsidian 750D, Corsair RM1000 (yellow label)
My build: Mira - Ryzen 7 3700X, 32GB EVGA DDR4-3200, ASUS Prime X470-PRO, EVGA RTX 3070 XC3, beQuiet Dark Base 900, EVGA 1000 G6
https://linustechtips.com/topic/565419-compression-fittings/#findComment-7431742
